Anyone have any experience with The Budgie 6DJ8 phono pre from Parks Audio?
Mike
Mike
Depends to some extent on the tube set being employed I would think. I have no way to measure mine, but it is certainly subectively quieter than the vast majority of SS phono stages I've owned. Published specs are S/N 86db, not too shabby. By comparison the phono stage in my Yamaha CA-1010 (MM setting) is rated at 82db. Neither is in the same league as my C-4 which is rated at 97db. Not sure what the S/N ratio of the various SS phono pre's being discussed of late is like, but I don't imagine noise is an issue for any of them. Can't speak to other tube units, though.G'day all, yes it looks nice, but I really wonder how quiet can a valve based phono stage really be? :scratch2: Regards, Felix aka catman.
Hmmm.... The distortion figures are exactly the same as for a number of the current crop of separate SS stages and clearly superior @ .01% THD to many including the highly-touted Clearaudio Nano @ .04% (which I owned previous to the Opera). Even so I don't think published specs reveal much past a point. My CJ PV12 pre has nowhere near the specs of a good SS unit, yet in terms of what comes out of the speakers it trounces anything else that has come through the door in my home by a wide margin. In the final assessment it is the subjective that wins the day, no? Provided the measurements are beyond a certain threshold (no idea where that cutoff point might actually be) it seems a design lifts itself into at the least the realm of sweet possibility.G'day mate, looking at that website the general specs all look considerably worse than a modern top notch solid state phono stage.
Edit: another source puts the S/N of the highly regarded C-4 at 85db, so actually about the same as the Opera unit.
I guess this is generally expected in valve gear and isn't necessarily a condemnation, however the quoted distortion figures might be a concern. Still I'd like to listen to it myself. Regards, Felix aka catman.
Wunderbar! Glad it is coming through for you. What is the tube set that came with it? Just curious.Just listened to Steely Dan aja mfsl (twice). Blown away
Mike
Does it have provisions for adjustable capacitance loading for the MM phono cartridge input?
