Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 07-16-2013, 02:32 PM
stopkidding stopkidding is offline
AK Member
Faint but audible hum from VPI Traveler
more than a hum, its sort of a buzz-umble, sort of what you get when the grounding wire is out. Ordinarily it is something I would not notice, when the platter is idle, and the volume on the amp is around 10 o'clock on my Sansui G-99X (160W @ 8ohm).
Now when I touch the wire or the DIN connector coming out of the tone arm the hum goes away, which makes me think its a grounding issue. It also goes away when I touch the base of the tonearm mount or the tonearm itself.
Now, is this typical? If Yes, then would running a piece of wire from the outside of the DIN connector to the ground lug help?
If this is not typical? is there something wrong with my tonearm wire DIN connector?
__________________
Main system: Sansui AU-Alpha 607MR, Polk LSi15, Yamaha PF-800 Sumiko BPS EVO3, Yamaha CD-S2000
System2: Sansui AU-7500, Polk RTi6, Technics SB-6060, VPI Traveler + Grado Gold1, TU-417, Pioneer SACD/DVD
Backup: Sansui AU-D11 (Mk1 & Mk2), Sansui AU-G99X, Technics SB-6060
  #2
Old 07-16-2013, 02:51 PM
andyecon andyecon is offline
AK Member
If the mechanism for connecting the grounding wire is the same on the Traveler as on the Scout then you might check that it hasn't come loose. That definitely sounds like a grounding issue.
__________________
Garrard 301 / Focusrite Forte / Mac Mini / Equator D8
My Discogs:
http://www.discogs.com/collection?user=andyecon
  #3
Old 07-16-2013, 02:55 PM
AK Member
the mechanism is secure and I checked a couple of times. What does bother me is that recently I bought a Gingko turntable cover, that sits on the table top (didn't buy their platform) and when the cover is on, the tone arm wire is slightly pushed down by the cover. I am wondering if that is putting pressure on the cable joints...
__________________
  #4
Old 07-16-2013, 06:11 PM
eurekaiv's Avatar
eurekaiv eurekaiv is offline
Irritable
I noticed that when setting up my traveler over the weekend that if I didn't get the DIN connector seated fully it would hum slightly, or like crazy, depending on how it was jiggled. You've probably already checked but I would give it a good push to make sure it's all the way in. My socket is pretty tight so it required a little more force then I was comfortable with at first. And I apologize for all the innuendo in this post.
__________________
VPI HW-19 Mk III (upgraded to IV) with a SAMA, Acos Lustre GST-1, Dynavecor DV-20XL, Luxman C-02, 2 Monarchy SM70s, Polk RTA12
  #5
Old 07-17-2013, 08:18 AM
KOWHeigel's Avatar
KOWHeigel KOWHeigel is offline
High Gear of Your Soul
Quote:
This makes me smile and laugh.
For the OP what cart are you using?
__________________
Analog: VPI Classic, VPI 16.5, Hypnotoad AD797 w/ OPS, AT OC9/MLii
Digital: Schiit Modi, HRT MS II, Sony PS1, SBT clone
Amps: Decware Torii Mk. II, Arcam Alpha 10
Speakers: Decware MG944, ADS L880
Audiokarma
  #6
Old 07-28-2013, 10:33 PM
zenith2134's Avatar
zenith2134 zenith2134 is offline
AK Member
While I love VPI, it would better suit my needs if their "entry-level" was more consistent in terms of build. No doubt these tables sound great (especially after arm/cart matching.)
Many companies are seemingly skimping on R&D as of late. That's in my own opinion, as a consumer of audio goods.
  #7
Old 07-29-2013, 03:22 AM
AK Member
I am using a Sumiko Blue Point Special EVO 3. The hum is there when you crank up the volume, but I can't seem to get rid of it. It does not interfere with listening music at normal-high volume. I can only hear it when I go looking for it. So I guess that's okay for now...
__________________
  #8
Old 07-29-2013, 06:38 AM
beatcomber's Avatar
beatcomber beatcomber is offline
AK Member
VPI is a small, family-run company. Why not call them and talk to them about it? 732-583-6895
From what I've heard, they stand by their products very well.
__________________
'61 Thorens TD-124 + '71 SME 3009 S2 + Grado 8MR/MCZ | marcmorin-ified c.'64 AR-TX + Grado G2/8MZ
c.'56 Rek-O-Kut L-34 + 160 mono arm + GE VRII | Dual 1019, 1219
Fisher 400 | Yamaha CR-1020 | Pioneer SX-780 | Rotel RCD-1072 | Teac A-2340
KEF LS50 | '67 AR4x | '71 KLH Six
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
AudioFriends
Capacitor World
Okki Nokki
Analog Engineering Associates
Vintage Home Audio
Organ Donor Parts
Hudson Valley Hi Fi
Wargos Electronics
Take Five Audio
Parts Connexion
Sound Stage Direct
Simply Speakers
Audience AV
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
