Pioneer SA-8800 Recap
SYK3S
hi guys im looking to recap my sa-8800
does any one have a recap list ?
thanks in advance
Sykes:thmbsp:
If you can get a copy of the SA-8800 service manual, then copy and post what the Pioneer part numbers and ratings of the capacitors are and which board part number they fit to. It will be a lot easier for someone to help you with recommended replacements.
So you can see the recommended format for the list, and what each line means, read this post by moschops about his SA-8100:
http://audiokarma.org/forums/showthread.php?t=463178
If we get a list together, I will add it to my recap lists thread :thmbsp:
http://www.audiokarma.org/forums/showthread.php?t=457663&highlight=sticky
Recap it in stages, not all in one fell swoop. And do the power supply first with special attention to the regulator board. Test the set after each stage of recapping.
Fred
owner
Classic Audio Repair
Mattsd made this list, found it in my records...
http://www.audiokarma.org/forums/showpost.php?p=4518561&postcount=14
It's not (yet) on Marty, Socal's list, plus it is only caps, I have not expanded it to semiconductors, trimpots etc yet.
I just ran it into mouser, and corrected 5 caps that turned up on back order.
EQ Assembly (GWF-113)
GWF-113: C3: 4.7uF 25 Non-Polar: 4.7 35 647-UEP1V4R7MDD
GWF-113: C4: 4.7uF 25 Non-Polar: 4.7 35 647-UEP1V4R7MDD
GWF-113: C5: 22uF 35 CEA: 22 35 647-UPW1V220MDD
GWF-113: C6: 22uF 35 CEA: 22 35 647-UPW1V220MDD
GWF-113: C7: 22uF 35 CEA: 22 35 647-UPW1V220MDD
GWF-113: C8: 22uF 35 CEA: 22 35 647-UPW1V220MDD
GWF-113: C19: 100uF 10 CEA: 100 10 647-UPW1A101MDD6
GWF-113: C20: 100uF 10 CEA: 100 10 647-UPW1A101MDD6
GWF-113: C21: 100uF 10 CEA: 100 10 647-UPW1A101MDD6
GWF-113: C22: 100uF 10 CEA: 100 10 647-UPW1A101MDD6
GWF-113: C29: 4.7uF 25 Non-Polar: 4.7 35 647-UEP1V4R7MDD
GWF-113: C30: 4.7uF 25 Non-Polar: 4.7 35 647-UEP1V4R7MDD
GWF-113: C31: 47uF 50 CEA: 47 50 647-UPW1H470MED
GWF-113: C32: 47uF 50 CEA: 47 50 647-UPW1H470MED
GWF-113: C35: 2200uF 6.8 Non-Polar: 2200 10 647-UVP1A222MHD
GWF-113: C36: 2200uF 6.8 Non-Polar: 2200 10 647-UVP1A222MHD
TC Assembly (GWG-122)
GWG-122: C7: 1uF 50 CEA: 1 50 647-UPW1H010MDD
GWG-122: C8: 1uF 50 CEA: 1 50 647-UPW1H010MDD
GWG-122: C9: 10uF 16 CEANL: 10 25 647-UKL1E100KDDANA
GWG-122: C10: 10uF 16 CEANL: 10 25 647-UKL1E100KDDANA
GWG-122: C19: 4.7uF 25 Non-Polar: 4.7 35 647-UEP1V4R7MDD
GWG-122: C20: 4.7uF 25 Non-Polar: 4.7 35 647-UEP1V4R7MDD
GWG-122: C57: 22uF 16 CEANL: 22 50 647-UKL1H220MEDANA
GWG-122: C58: 22uF 16 CEANL: 22 50 647-UKL1H220MEDANA
PA Assembly (GWH-115)
GWH-115: C31: 47uF 63 CEA: 47 63 647-UPW1J470MPD
GWH-115: C32: 47uF 63 CEA: 47 63 647-UPW1J470MPD
GWH-115: C33: 4.7uF 25 Non-Polar: 4.7 35 647-UEP1V4R7MDD
GWH-115: C34: 4.7uF 25 Non-Polar: 4.7 35 647-UEP1V4R7MDD
Indicator Assembly (AWV-001)
AWV-001: C3: 1uF 50 CEA: 1 50 647-UPW1H010MDD
AWV-001: C4: 1uF 50 CEA: 1 50 647-UPW1H010MDD
AWV-001: C5: 2.2uF 50 CEA: 2.2 50 647-UPW1H2R2MDD
AWV-001: C6: 2.2uF 50 CEA: 2.2 50 647-UPW1H2R2MDD
AWV-001: C9: 47uF 10 CEA: 47 50 647-UPW1H470MED
AWV-001: C10: 47uF 25 CEA: 47 50 647-UPW1H470MED
AWV-001: C11: 47uF 50 CEA: 47 50 647-UPW1H470MED
AWV-001: C12: 47uF 25 CEA: 47 50 647-UPW1H470MED
AWV-001: C13: 2.2uF 50 CEA: 2.2 50 647-UPW1H2R2MDD
Power Supply Assembly (AWR-182)
AWR-182: C9: 220uF 80 CEA: 220 100 647-UHE2A221MHD
AWR-182: C10: 220uF 80 CEA: 220 100 647-UHE2A221MHD
AWR-182: C13: 100uF 10 CEA: 100 10 647-UPW1A101MDD6
AWR-182: C14: 47uF 63 CEA: 47 63 647-UPW1J470MPD
AWR-182: C15: 47uF 63 CEA: 47 63 647-UPW1J470MPD
AWR-182: C18: 47uF 50 CEA: 47 50 647-UPW1H470MED
AWR-182: C19: 47uF 50 CEA: 47 50 647-UPW1H470MED
AWR-182: C22: 2.2uF 50 CEANL: 2.2 50 647-UKL1H2R2KDDANA
AWR-182: C23: 1uF 63 CEA: 1 100 647-UPW2A010MDD
AWR-182: C24: 100uF 16 CEA: 100 25 647-UPW1E101MED
AWR-182: C25: 470uF 6.8 Non-Polar: 470 16 647-UES1C471MHM
parts importer list:
647-UEP1V4R7MDD
647-UEP1V4R7MDD
647-UPW1V220MDD
647-UPW1V220MDD
647-UPW1V220MDD
647-UPW1V220MDD
647-UPW1A101MDD6
647-UPW1A101MDD6
647-UPW1A101MDD6
647-UPW1A101MDD6
647-UEP1V4R7MDD
647-UEP1V4R7MDD
647-UPW1H470MED
647-UPW1H470MED
647-UVP1A222MHD
647-UVP1A222MHD
647-UPW1H010MDD
647-UPW1H010MDD
647-UKL1E100KDDANA
647-UKL1E100KDDANA
647-UEP1V4R7MDD
647-UEP1V4R7MDD
647-UKL1H220MEDANA
647-UKL1H220MEDANA
647-UPW1J470MPD
647-UPW1J470MPD
647-UEP1V4R7MDD
647-UEP1V4R7MDD
647-UPW1H010MDD
647-UPW1H010MDD
647-UPW1H2R2MDD
647-UPW1H2R2MDD
647-UPW1H470MED
647-UPW1H470MED
647-UPW1H470MED
647-UPW1H470MED
647-UPW1H2R2MDD
647-UHE2A221MHD
647-UHE2A221MHD
647-UPW1A101MDD6
647-UPW1J470MPD
647-UPW1J470MPD
647-UPW1H470MED
647-UPW1H470MED
647-UKL1H2R2KDDANA
647-UPW2A010MDD
647-UPW1E101MED
647-UES1C471MHM
