I thought that I'd change my FM dipole from a 1/2 wave speaker wire feed to 300Ω terminals to speaker wire dipole attached to a coax feed to the 75Ω terminals.
This setup is a Technics SA-404 in the back of my classroom and the antenna up at the ceiling near fluorescent fixtures. So I thought that changing to a coax feed would help with any noise from them. I did not use cable TV coax- it was RG59/U RCA cable. I checked the impedance and it is 75Ω, so there is not really any difference.
The questions:
1. One of the stations that I listen to is a college station across the street from my school and it is a strong signal. I have noticed that I hear it on its assigned 89.7 but also two spots just above that (highest one is at about 90.5-ish). By rotating the dipole around, I can eliminate the two ghost images. Why does this occur (the freq shift)? It does not seem to be a harmonics thing. And I don't think that multipath interference can cause alternate freq ghost images, correct?
2. Why has there not been the cleaner signal on 75Ω that I had hoped for. I am trying to tune my normal 90.5 station and it barely receives in stereo- and with a lot of hiss noise. This station is ~30 mi as the crow flies. RadioLocator.com shows that I am inside the "distant" circumference but it seems like I am receiving a fringe signal.
I know that antenna design and implementation is a black art but can some of you shed some light and provide some answers on this?
Thanks,
Tyler
The questions:
Thanks,
Tyler
