Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Pioneer Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 12-12-2005, 11:35 AM
rmunson's Avatar
rmunson rmunson is offline
console destructor
scratchy sound: is it my receiver or my speaker?
Hi Everyone --
well, I'm having a little problem with my sx-727 -- the right speaker is scratchy and cuts out intermittantly. I have a pair of Klipsch KG4s.
I have tried:
using the three different speaker ports in the back of the sx-727 receiver.
using different cables - (same bannana connectors on the speaker end and funny pioneer spade speaker plugs on the receiver end) but first was using 10 gauge monster wire and then tried some cheap 16 gauge speaker wire
Powering the system off and the powering it back on...
All of these attempts have not solved the problem - scratchiness on right speaker comes back after a while. The scratchiness is present with FM tuner, CD (aux) and phono...
What do you all think? A problem in my speaker or a problem with my SX-727?
Please advise -- any suggestions would be greatly appreciated.
Reed
Minneapolis, MN
  #2
Old 12-12-2005, 11:37 AM
tentoze's Avatar
tentoze tentoze is offline
Twangophile
Doubt it's a speaker issue. Swap the speakers left to right and see if the noise follows the speaker. Chances are it won't. Then get some DeOxit and clean the pots.
__________________
"If evil exists, it's a pair of train tracks,
And the Devil is a railroad car."
-Josh Ritter-
  #3
Old 12-12-2005, 01:25 PM
joenielsen joenielsen is offline
AK Member
I would definitely try cleaning all the pots and switches with Deoxit.
  #4
Old 12-12-2005, 01:27 PM
AK Member
By the way, I forgot to mention that I have a SX-727 as well and am enjoying it a lot. Cleaning the pots/switches is not very difficult.
  #5
Old 12-12-2005, 01:35 PM
ARguy's Avatar
ARguy ARguy is offline
AR Collector
The likely culprit is your balance control which nobody ever uses. Try twisting that back and forth a couple dozen times (power off) and see if that improves anything. If so then get out the Deoxit and clean away the grime!
__________________
Preserving the Acoustic Research brand one piece at a time.
Audiokarma
  #6
Old 12-12-2005, 01:45 PM
Groovy's Avatar
Groovy Groovy is offline
I AM CANADIAN
Yes I agree.......9x out of 10 dirty volume pot or balance, on my sx-850 have had the same problem on a few occasions,
__________________
We are all going the wrong way on a one way street... :dammit:
  #7
Old 12-12-2005, 02:17 PM
rmunson's Avatar
console destructor
Sweet! thanks everybody! I'll give this a try as soon as I figure out how to clean the pots with deoxit ---
Thanks!
Reed
  #8
Old 12-12-2005, 03:06 PM
hpsenicka's Avatar
hpsenicka hpsenicka is offline
Moderator
There are likely a number of threads that discuss various cleaning methods... you can use the search function to help find them.
In a nutshell, you will need to remove the outer case to gain access to the pots and switches from the inside.
Examine the construction of each switch assembly... on most gear the actual switch contact surfaces are encased inside a protective housing.
Many times you can find small opening in which you can spray (or inject) a bit of DeOxit. DeOxit has a surprising capability to "creep" into crack and small openings... but sometimes you still need to use some patience and determiniation to find a way to get the cleaner into the contacts. Use gravity to your advantage (if necessary) to promote the flow of the solution into the switch assembly through whatever openings are available.
As you liberally apply DeOxit solution to the contact surfaces, operate the switch repeatedly through its full range of motion, and follow up with a flush or rinse of DeOxit.
If the contacts are actually exposed and visible, this becomes a very easy job.
In extreme cases it may be necessary to partially dismantle the switch assembly to expose the contact surfaces, but this is not a procedure for the novice.
  #9
Old 12-12-2005, 03:18 PM
rmunson's Avatar
console destructor
Great! Thanks so much!
Reed
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
