Watthour
Electron Rancher - JS3600
I have a single voltage SX-750 which exhibits random static burst in the L channel.
The History - The unit was a DOA purchase, shipped in safely, and was in generally poor condition with lights out, one "dead" channel, hum/buzz in the other, and various other maladies. The power supply had AC leaking through C16/C17 and various hot transistors and suspect solder joints. The treble control shaft was frozen and snapped off. The unit appears to have been serviced at some past time as evidenced by the soldered wire-wrap connections in several locations.
The Remedies - The PS was mostly rebuilt and voltages are within 3-5% of specs. The AC component in the supplies is reduced to a minor ripple on the Tektronics and there is no hum present in the audio output. The treble control was replaced with an OEM take-out and all other controls were cleaned. The speaker relay contacts have been burnished, function and speaker switches cleaned. Once warmed, idle currents are set and stable at 29.5/29.8 mV L/R with no apparent excursions during the static episodes.
The Symptoms - The audible static burst phenomenon occurs in all modes, through both the "A" and "B" left speaker outputs, and seems to occur most frequently at lower volume levels including at zero volume. No static occurs in the R channel - Ever. Switching from STEREO to MONO mode does not change the occasional burst and does not translate it to the R channel, leading me to believe the problem is after that switch.
The Questions - I expect the cause is in the left final amp stage but there are none of the usual suspects installed in that circuit. There IS a 2SC1438 in the power amp pre-driver section, but that is not on my list of problem devices. Is that also a commonly suspected device? Is it more likely that a cap in that section is failing?
The few 725s in the unit are in the phono preamps and the lone 725/1344 in the MIC EQ amp, but those are easily switched out of circuit. The tone amp is after the MONO switch but uses SIP amps (TA7136P1) instead of discretes. Are those also suspect?
As always, any advice is appreciated.
