Flaxmill19
Hi All,
I have an interesting and probably very difficult problem to overcome, this has a very long history, so here goes.
I am the original owner of this 140 amp and a 3200 pre amp, not long after I purchased the pair in the late 70’s I somehow (don’t ask, I cringe every time I think about this) connected the output of the 140 (via the 3200) to the output of another amp (lower power output, probably about 25 watts). And I assume that an output voltage from the other amp found its way into the output of the 140 amp. Because from this day on, normally a short time after turning the amp on, the right channel voltage would fluctuate about 5 to 10dB, this can be heard through the speaker as a loud pulsing sound. If you switch the amp off and on the fluctuating will go away, normally until the amp is turned off and left (say overnight) and the turned on again. The volume and amp gain controls have no effect on the fluctuating. Here is the curve ball, this does not happen all the time, say once every 5 to 6 times you turn it on.
I then gave the amp to my sister who’s used it for a few years and then stored it under the house for about the last 15 years. I recently (eight months ago) reclaimed the amp & pre amp. I cleaned them up and re-capped (except the 13000 x 2 uf main power filter cap) them both and up until last weekend all has been fine, in fact excellent, I love the sound of these amps. BUT out of the blue the fluctuating has started again, this is most frustrating as I thought replacing the caps had cured the problem, not to be. I suspect the main output transistors, but have no evidence only a hunch as these would have seen the incoming voltage (from the output) first.
I am about replace the filter cap in the 140 and some other cap changes on the 3200. So prior to the commencement of this work I would like to ask our experienced Audiokarma tech’s (or would be tech’s) if they have any ideas on what this could possibly be? I suspect because of it being so intermittent it will be very difficult to diagnose and I don’t want to get into replacing components just for the sake of it.
So any suggestions and/or ideas would be greatly appreciated.
Tony
Tony
what part of the circuit are these transistors part of?
