Hi Folks,
in my usual verbose style...
1) Brush vs no brush - the damper does work (I have measured the effect) - although not as effectively as the original Shure item - but it does damp LF resonance, and therefore helps by reducing higher level intermodulations as a result - it cleans things up. (and no I am not talking about dust - which will not be present on any of our records when being played.....right?)
Whether it is worth the addition $30 is a different question!
2) All the SAS styli appear identical - there does not to the best of my knowledge appear to be a difference between N97xSAS and VN5xSAS. BUT there are manufacturing variations between individual styli that can be quite pronounced.
The variations appear primarily in the tensioning system of the SAS, and result in variations in the cantilever resonance at 16kHz (16kHz I am guessing as the tension wire resonance and 28KHz as the main cantilever resonance - 28kHz is circa 8db).
I have 4 exemplars and the 16KHz resonance in 2 is slight, and in 1 is substantial, and 1 is middling. (worst is around 2.5db)
Due to the variance in the 16kHz resonance within the audible range, ideal setup has varied....
3) I have experimented with a range of shure bodies having inductances ranging from around 320mH (V15V) to 700mH (MT105p), and the range of available inductances allowed me to tune all 3 critical parameters - Inductance, capacitance and resistance.
With the SAS having the largest 16kHz resonance, best results were achieved by using a high inductance body (700mH), with 47k ohm and around 350pf
With the "smoothest" SAS I found the low inductance body (320mH) combined with 26kOhm and 760pf capacitance to be best....
Unfortunately the "smoothest" SAS is a narrow shank VN5SAS so I cannot use it properly in the higher inductance bodies... clearly the SAS styli work best in higher inductance setups, and I am having to increase the capacitance to compensate for the low inductance in this case...
My objective was to achieve as smooth a frequency response as possible while still remaining as flat as possible - with priority given to below 16kHz (ie willing to have a slight rise or drop after 16kHz in exchange for better response below that)
With the two setups described above, the high inductance body with the more "resonant" SAS resulted in a very smooth response to 16kHz then dropping off quite quickly, the low inductance setup resulted in a similar response to 16kHz but only a slow drop off after that.
If I wanted to achieve flat or slightly rising top end response (16kHz to 20kHz) the trade off seems to be the resonance at 16kHz rising up - so you have a slight rise in the 8kHz to 16kHz range.
My advice without measuring the individual stylus is:
700mH body - 47k and 250pf to 300pf (if the 16kHz resonance is more prominent raise the C to 350pf)
500mH body - 47k and 400 to 500pf (again around 400pf if smooth, 500pf if the 16kHz is not so well controlled)
Although I have experimented with low inductance and low capacitance setups, these expose the cantilever behaviour quite harshly - great for figuring out what is happening in terms of cantilever resonances etc... but not so good for listening (but if you like a substantially rising high end, contrasting with a slightly depressed midrange then this might be your thing...)
There you go - my personal 2bits
Short version of the above:
In my opinion, the brush is worth the extra $30, and I would opt for the higher inductance body.
bye for now
David
