SA-1000 Cap List for Vetting.
larryderouin
I'm VERTICAL and Breathing...most of the time.
FINAL LIST IS IN POST #10. DO NOT USE LIST IN POST #1.
This is the companion list to the SA-1000 Transistor list.
there are a couple of parts I wasn't sure on or couldn't xref, so left them blank. Both are DIODE Numbers.
THIS LIST IS PRELIMINARY USE FINAL LIST IN POST #10
ALL PART #'s are MOUSER and in stock as of 29SEPT 2013. Prices are current as of that date.
There are a couple of parts I couldn't XREF. UNTIL THEY ARE, This is STILL A Preliminary List.
The VALUE/VOLTS on any cap after the price is the replacement cap values.
SA-1000 Capacitor's, Diodes
POWER SUPPLY (W16-035)
C2 1000uf 10V CEA UPW 647-UPW1E102MHD...$.49
C3 100uf/50V CEA ... UPW 647-UPW1H101MPD...$.41
C4 100uf/50V CEA ... UPW 647-UPW1H101MPD...$.41
C5 100uf/50V CEA ... UPW 647-UPW1H101MPD...$.41
C6 100uf/50V CEA ... UPW 647-UPW1H101MPD ..$.41
C8 220uf 35V CEA ... UPW 647-UPW1V221MPD ..$.39
D1 SR3AM -> 1n5406 512-1N5406.........................$.51
D2 SR3AM -> 1n5406 512-1N5406.........................$.51
D3 SR3AM -> 1n5406 512-1N5406 ........................$.51
D4 SR3AM -> 1n5406 512-1N5406 ........................$.51
D5 FR2-02 -> 1n4007 512-1N4007........................$.14
D6 1S1850 ->
D7 WZ-130 13V/0.5W ZENER -> 512-1n5243b ......$.12
HEAD AMP (W21-007)
C1 1uf/25V CSSA ... 667-ECQ-V1H105JL3.......$.68 1uf/50V
C2 1uf/25V CSSA ... 667-ECQ-V1H105JL3........$.68 1uf/50V
C3 4.7uf/25v CEA ... 647-UKL1E4R7KDD...........$.15
C4 4.7uf 25V CEA ... 647-UKL1E4R7KDD...........$.15
C5 10uf /25V CEA ... 647-UKL1E100KDDANA ..$.37
C6 10uf/25V CEA ... 647-UKL1E100KDDANA ..$.37
C15 100uf/35V CEA .. 647-UKL1V101KPDANA ..$.64
CONTROL AMP (W15-050)
C3 30uf/6V CEA ................. 647-UKL1C330KDDANA $.35 33uf/16V
C4 30uf/6V CEA ................. 647-UKL1C330KDDANA..$.35 33uf/16V
C7 4.7uf 25V CEA ............. 647-UKL1E4R7KDD .......$.15
C8 4.7uf/25V CEA ............. 647-UKL1E4R7KDD .......$.15
C11 10uf/ 25V CEA ........... 647-UKL1E100KDDANA $.37
C12 10uf/ 25V CEA .......... 647-UKL1E100KDDANA $.37
C13 10uf/ 25V CEA ......... 647-UKL1E100KDDANA $.37
C14 10uf/ 25V CEA ......... 647-UKL1E100KDDANA $.37
C25 220uf/35V CEA ........ 647-UKL1V221KPD.......... $.77 220uf/35V
FILTER UNIT (W28-004)
C9 1uf/25V CEA ......... 667-ECQ-V1H105JL3 ..........$.68
C10 1uf/25V CEA ....... 667-ECQ-V1H105JL3...........$.68
C19 10uf/16V CEA ....... 647-UKL1E100KDDANA....$.37
C20 10uf/16V CEA ........647-UKL1E100KDDANA..$.37
C25 220uf/25V CEA ...... 647-UKL1V221KPD........ $.77 220uf/35V
MAIN AMP (W23-008)
C1 2.2uf/25V CSSA ....... 667-ECQ-V1H225JL............$1.09 2.2uf/50V
C2 2.2uf/25V CSSA ........667-ECQ-V1H225JL............$1.09 2.2uf/50V
C5 22uf/6V CEA ............. 647-UKL1C220KDDANA....$.33 22uf/16V
C6 22uf/6V CEA ..............647-UKL1C220KDDANA ...$.33 22uf/16V
C11 220uf/10V CEA........647-UKL1V221KPD............$.77 220uf/35V
C12 220uf/10V CEA .......647-UKL1V221KPD ...........$.77 220uf/35V
C13 100uf/50V CEA .......647-UKL1H101KPD ...........$.56
C14 100uf/50V CEA .......647-UKL1H101KPD........... $.56
D1 WZ-130 (ZENER 13V/ .5W)-> 512-1n5243b .......$.12
D2 WZ-130 (ZENER 13V/ .5W) -> 512-1n5243b.......$.12
D3 SH-1S -> 1n4007 ......................512-1N4007.........$.14
D4 SH-1S -> 1n4007......................512-1N4007.........$.14
D5 1s1212 -> ????1n4148 or 1n914????
VR1 4.7K trimmer Top adjust 652-3296W-1-502LF $1.74 5.0K oHm
VR2 4.7K trimmer Top Adjust 652-3296W-1-502LF $1.74 5.0K oHm
VR3 1.5K trimmer Top Adjust 652-3296W-1-502LF $1.74 2.0K oHm
VR4 1.5K trimmer Top Adjust 652-3296W-1-502LF $1.74 2.0K oHm
PROTECTION UNIT(W28-008)
C3 220uf/10V CEA 647-UKL1V221KPD .........$.77 220uf/35V
C4 220uf/10V CEA 647-UKL1V221KPD..........$.77 220uf/35V
C6 100uf/16V CEA 647-UKL1V101KPDANA ..$.64 100uf/35V
D1 SIB01 -> 1n4007 512-1N4007 $.14
D2 SIB01 -> 1n4007 512-1N4007 $.14
D3 SIB01 -> 1n4007 512-1N4007 $.14
D4 SIB01 -> 1n4007 512-1N4007 $.14
D5 SIB01 -> 1n4007 512-1N4007 $.14
D6 SIB01 -> 1n4007 512-1N4007 $.14
D7 SIB01 -> 1n4007 512-1N4007 $.14
D8 VB11-A ????......spec:Mitsubishi GE-ST 10ma, Uf=0.16V(1mA)
D9 VB11-A ???? Same as D8
VR1 100ohm trimmer Top adjust......652-3296W-1-101LF.........$1.74
MISCELLANEOUS PARTS
Main Filter caps.....
C33, 4700uf/50V 647-UVZ1H472MRD $3.19
C34, 4700uf/50V 647-UVZ1H472MRD $3.19
C35, 4700uf/50V 647-UVZ1H472MRD $3.19
C36 4700uf/50V 647-UVZ1H472MRD $3.19
C37 1000uf/63V 647-UPW1J102MHD $2.55
C38,C39 0.01uf/450VAC 0.01uf/ X-Y rated Safety caps
C42 47uf/50V CEA AXIAL....647-TVX1H470MAD $.54
............................................PRELIMINARY LIST. DO NOT USE.........USE LIST IN POST #10......................................
When both get vetted I'll clean them up and combine into one and make a BOM.
Larry
There are several errors in that list, but there's one very obvious oddity I saw. Why in the world are you using UKL low leakage caps for every single one of the CEA labeled caps except the power supply? :scratch2: Those are supposed to be replaced by UPW caps, the other option is Panasonic FM or FC (I prefer the latter, they have better tonal quality when used in the preamp area compared to UPW's). You only need UKL's for CSSA, CSZA and CEANL caps, and if they are 1uF or under, ECQ film caps.
I'll put up a list here soon, if not tonight tomorrow for sure.
Oversimplifying old habit. Power supply UPW's and signal path UKL's, 2.2uf & < ECQ's
1.) going directly from the manual. No unit to compare with.
2.) the 1s1212 replacement is a SWAG.
3.) VB-11 is a germanium diode. Not sure what goes in and couldn't find it via googling the forum. So just put up the specs.
Let's stick with Nichicon's. I like them and easier for me on the order end.
thanks
Larry
Pioneer SA-1000 Recap List
Here is the list:
IT IS NOT YET COMPLETE, DO NOT ORDER FROM UNTIL THIS LINE IS GONE.
Pioneer SA-1000 recap list with diodes, diodes don't have to be replaced.
Head Amp Board (W21-007)
W21-007: C1: 1uF 25v CSSA: 667-ECQ-V1H105JL3 1uF 50v
W21-007: C2: 1uF 25v CSSA: 667-ECQ-V1H105JL3 1uF 50v
W21-007: C3: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
W21-007: C4: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
W21-007: C5: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W21-007: C6: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W21-007: C15: 100uF 35v CEA: 647-UPW1H101MPD 100uF 50v
Control Amp Board (W15-050)
W15-050: C1: .1uF 25v CQMA (Mylar): 667-ECQ-V1H104JL3 .1uF 50v
W15-050: C2: .1uF 25v CQMA (Mylar): 667-ECQ-V1H104JL3 .1uF 50v
W15-050: C3: 30uF 6.3v CEA: 647-UPW1C330MDD 33uF 16v
W15-050: C4: 30uF 6.3v CEA: 647-UPW1C330MDD 33uF 16v
W15-050: C7: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
W15-050: C8: 4.7uF 25v CEA: 647-UPW1H4R7MDD 4.7uF 50v
W15-050: C11: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W15-050: C12: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W15-050: C13: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W15-050: C14: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W15-050: C15: 220uF 35v CEA: 647-UPW1H221MPD 220uF 50v
Filter Board (W28-004)
W28-004: C9: 1uF 25v CEA: 647-UPW1H010MDD 1uF 50v
W28-004: C10: 1uF 25v CEA: 647-UPW1H010MDD 1uF 50v
W28-004: C19: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W28-004: C20: 10uF 25v CEA: 647-UPW1V100MDD 10uF 35v
W28-004: C25: 220uF 25v CEA: 647-UPW1E221MPD 220uF 25v
Main Amp Board (W23-008)
W23-008: C1: 2.2uF 25v CSSA: 647-UKL1H2R2MDDANA 2.2uF 50v
W23-008: C2: 2.2uF 25v CSSA: 647-UKL1H2R2MDDANA 2.2uF 50v
W23-008: C5: 22uF 6.3v CEA: 647-UPW1A220MDD 22uF 10v
W23-008: C6: 22uF 6.3v CEA: 647-UPW1A220MDD 22uF 10v
W23-008: C11: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
W23-008: C12: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
W23-008: C13: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
W23-008: C14: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
VR1: 4.7K ohm multi offset: 652-3296Y-1-502LF 5K ohm 25 turn
VR2: 4.7K ohm multi offset: 652-3296Y-1-502LF 5K ohm 25 turn
VR3: 1.5K ohm single bias: 652-3386F-1-202LF 2K ohm single turn
VR4: 1.5K ohm single bias: 652-3386F-1-202LF 2K ohm single turn
D1: WZ-130: 512-1N5243B
D2: WZ-130: 512-1N5243B
D5: 1S1212: 512-1N4148
Protection Board (W28-008)
W28-008: C3: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
W28-008: C4: 220uF 10v CEA: 647-UPW1E221MPD 220uF 25v
W28-008: C6: 100uF 16v CEA: 647-UPW1E101MED 100uF 25v
D1: SIB01-005: 512-1N4005
D2: SIB01-005: 512-1N4005
D3: SIB01-005: 512-1N4005
D4 SIB01-005: 512-1N4005
D5 SIB01-005: 512-1N4005
D6 SIB01-005: 512-1N4005
D7 SIB01-005: 512-1N4005
VR1: 100 ohm single turn: 652-3386F-1-101LF 100 ohm single turn
Power Supply Board (W16-035)
W16-035: C2: 1000uF 10v CEA: 647-UPW1E102MHD 1000uF 25v
W16-035: C3: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
W16-035: C4: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
W16-035: C5: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
W16-035: C6: 100uF 50v CEA: 647-UPW1J101MPD 100uF 63v
W16-035: C7: 220uF 35v CEA: 647-UPW1H221MPD 220uF 50v
D1: SR3AM-8: 512-1N5404
D2: SR3AM-8: 512-1N5404
D3: SR3AM-8: 512-1N5404
D4: SR3AM-8: 512-1N5404
D5: FR2-02: 512-1N5404
D7: WZ-130: 512-1N5243B
Filter caps (need measurements of the main filter caps to determine replacements):
C33: 4700uF 50V
C34: 4700uF 50V
C35: 4700uF 50V
C36: 4700uF 50V
C37: 1000uF 63V
C42: 47uF 50V CEA: 647-UPW1J470MPD 47uF 63v
BOM List:
667-ECQ-V1H105JL3 | 2
647-UKL1H2R2MDDANA | 2
647-UPW1H4R7MDD | 4
647-UPW1V100MDD | 8
647-UPW1J101MPD | 6
647-UPW1H101MPD | 1
647-UPW1E101MED | 1
647-UPW1C330MDD | 2
667-ECQ-V1H104JL3 | 2
647-UPW1H221MPD | 2
647-UPW1E221MPD | 5
647-UPW1H010MDD | 2
647-UPW1A220MDD | 2
647-UPW1J470MPD | 1
647-UPW1E102MHD | 1
652-3296Y-1-502LF | 2
652-3386F-1-202LF | 2
652-3386F-1-101LF | 1
512-1N5243B | 3
512-1N4005 | 7
512-1N4148 | 1
512-1N5404 | 5
Still need to get the filter caps, I also skipped over some of the diodes as well since the datasheets for them are impossible to find.
please write down the datasheet numbers you could not find, and I will look into it as well.
some of those old units used germanium diodes :yikes:
I got a bunch of them a while back, just in case!
Mark: Diodes in POST 1 that are in BOLD are the one's I had trouble or not sure on. The one know germanium is on the protection board(W28-008) in position D8 & D9
D8 VB11-A
(I found this on the net @ datasheet archives ......spec:Mitsubishi GE-ST 10ma, Uf=0.16V(1mA))
D9....Same as D8
NTE lists their replacement as a NTE177. But knowing how much everyone "loves" NTE and how generic their tolerances can be, I left it off.
And then the 1s1850 @ D6 in the Power supply (w16-035)
Larry
Matt: The caps I listed for the Power supply should work as a starting point. The can's are clamped & I plan on stuffing my uncles, when I get it here (eventually from Montana). I normally use UVz if i can't get UPW's in the size and with the higher temp rating work well if inside a can.
Larry
d6 is a dual diode, nothing special, a pair of 512-1n4004's will do.
d5 the same, 52-1n4004
protection unit vb11-a : leave them be...
Marks recommendations added to list.
FINAL LIST! OK TO USE!!!!
D5: FR2-02: 512-1N4004
D6:1s1850: 1n4004 (x2) (original is dual diode cathode to center)
D7: WZ-130: 512-1N5243B[/b]
D8: Germanium diode leave it be. No readily available replacement.
D9: Germanium diode, leave it be. No readily available replacement.
C33: 4700uF 50V
C34: 4700uF 50V
C35: 4700uF 50V
C36: 4700uF 50V
C37: 1000uF 63V
BOM List:
647-UPW1H4R7MDD | 4
647-UPW1V100MDD | 8
647-UPW1J101MPD | 6
647-UPW1H101MPD | 1
647-UPW1E101MED | 1
647-UPW1C330MDD | 2
647-UPW1H221MPD | 2
647-UPW1E221MPD | 5
647-UPW1H010MDD | 2
647-UPW1A220MDD | 2
647-UPW1J470MPD | 1
647-UPW1E102MHD | 1
512-1N5243B | 3
512-1N4005 | 7
512-1N4148 | 1
512-1N5404 | 4
512-1n4004 | 3
..............................end of list........................................................
Thank you Mark.
MattSD: I made the changes proposed by MTF. Added 1s1850 (1n4004 x2) changed D5 to
1n4004. I've used 1n400X in place of FR2-02s in TEAC and FISHER Gear with no problems. BOM Changes made (Subtracted 1-1n5404, added 3 1n4004)
Larry
CONSOLIDATED FULL PARTS LISTS HERE:http://www.audiokarma.org/forums/showthread.php?t=549424
Transistors list only HERE; http://www.audiokarma.org/forums/showthread.php?t=546251
Bump and a big thanks to everyone who put this very good list together!! Got another back in the saddle! They do sound very good,!! :beerchug:
Bumping this once again....
As I bring this unit out for a rotation, I have noticed that the unit doesn't really sound up to snuff?? After my refurb I never really used it very much but I recently found a matching tx-600 tuner and set them up. Maybe this unit has more of a bloated tone? It sure seems as if it's quite underpowered almost?? Easily distorts with little added bass and less overall clear at higher volumes?
Operates normal, no oscillation but perhaps the outputs are not ideal??
I found it sounded pretty much the same with a separate presmp as well ...
Edit: I just realized that the only thing I never changed were the main power supply filter caps.... Maybe they should be swapped? Sound like a likely culprit??
