Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Speakers
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 10-19-2013, 05:08 AM
memustbefree memustbefree is offline
AK Member
yamaha NS-200Ma
Found this Yamis in an old warehouse we cleaned out at work today, everything was going to the dump but not this ones they got a ride home with me. And now iam really glad i saved them!
They sound GOOD but one cabinet are badly water damaged, anyone have fixed a cabinet this damage?
what would be the best way to clean up the aluminium around the woofer?
  #2
Old 10-19-2013, 11:26 PM
AK Member
I toke out the drivers and clean them up but its just mold every were in the cabinet so i think i will build new ones.
but my Q are should i just copy the original or go with something different?
I have Australian ash to build a par of the originals, hard wood vs particle board vs MDF?
  #3
Old 10-20-2013, 03:22 AM
Bratwurst7s's Avatar
Bratwurst7s Bratwurst7s is offline
In The Frying Pan
As far as cleaning the alu frames, iirc from my etching days tap water and rainwater is usually slightly acidic, say ph 5.5 to 6 or so. We used to clean up aluminum with a slightly caustic solution, say ph 8 or so. ph 7 is neutral.
So you could try putting a small amount of baking soda in some water, and use moist scotch-brite to polish them. Dip your scotch brite and wring out the water till it's just moist. You can get scotch-brite in various grits and can polish alu quite fine with it. Take your time and wipe clean with a cloth from time to time to check how it looks.
Depending on how deep the corrosion went they will probably still be pitted but you can at least remove the scale that way. Dry them completely and if you want to protect them from further damage carefully brush them with clear lacquer. Make sure they are 100% dry first.
The area where those steel mounting screws are/were will probably be the worst because of dissimilar metal corrosion. The screws themselves rusting accelerates things. SS screws would be a better choice.
__________________
Yamaha AX-1090, + DSP-E800. Speakerlab S7s, Infinity Alpha Center/Rear, Infinity Modulus II 8" Sub, Onkyo DX-6900.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
AudioFriends
Capacitor World
Okki Nokki
Analog Engineering Associates
Vintage Home Audio
Organ Donor Parts
Hudson Valley Hi Fi
Wargos Electronics
Take Five Audio
Parts Connexion
Sound Stage Direct
Simply Speakers
Audience AV
Howard Products
AudioClassics
The Tube Store
FM DX Antenna
RSL Speakers
Many Moons Audio
Audio Doctor
BOI Audio Works
Yesterday's Audio
DeWick Repairs
Amplifiedparts
Politicalchat.org
MCM Electronics
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
