I have a P-500, the pro model of the DH-500. Here are the differences:
Connections:
- XLR inputs
- Barrier strip inputs
- No RCA inputs.
Display:
- Clipping LEDs - one per channel
- Activity LED - one per channel
- Volume controls - one per channel
- Much heavier duty AC on/off switch
Internal circuits/boards:
- Additional board for the clipping, input controls, and balanced-to-unbalanced signal conversion. Mounted behind the front panel.
- Differences in fan resistor values. This changed the speed at which the cooling fan ran.
- Air filters installed on both of the air inputs. Mounted in the same place as the DH-500, there were 'pouches' where mesh filters could be installed for long-term operation and keeping the interior cleaner of dust.
Otherwise, the chassis, driver boards, heatsink, speaker relay, and power supply components were exactly the same as the DH-500. I suspect that the power supply's ground rails were a bit heavier between the capacitors.
There is some additional wiring in the harnesses to accommodate the additional board and rear connections.
Hope that helps.
Cheers,
David
