I'm truly sorry if you've only heard mediocrity. Not all recording engineers are deaf and utterly clueless.
Perhaps you should read up on AMS Calrec, and some of the PEOPLE who design and build them. Here's an article on Chris Gaunt, main engineer, had some nice experience in HiFi before moving on to Electrical Engineering and production. Recording desks sounded good for Abba to install in their studios and in use around the world.
CHRIS GAUNT HAS SPENT his entire
working life in the audio industry with his
interest stretching back to ‘doing the sound’
for dramas while at school and a Saturday job in a hifi
shop where he was introduced to the wonders of the
Quad Electrostatic. He studied Electronic Engineering
at university and developed skills in organising a
range of social events, which sometimes included
setting up the lighting and sound. After graduating
he installed and serviced sound equipment in the
ballrooms and nightclubs of the MECCA group before
joining Calrec as the test department supervisor in
1978, where he worked on the J-Series, L-Series and
M-Series broadcast consoles and moved from testing
into system design and project management. He was
one of the driving forces behind Calrec’s UA8000
music console, project managing the design and
build, and taking responsibility for all schematics and
backplane design, and even installed the first desk at
Abba’s Polar Studios.
Following the purchase of Calrec by AMS in 1986,
Chris spent more than ten years with AMS in several
roles and contributed significantly to its digital console
projects before rejoining Calrec in 1998 after it had
spun off again on its own. He has overseen the
development of Calrec’s entire range of digital desks
and is responsible for the continued development
of the Alpha, Sigma and Zeta System Plus range of
consoles. He is also involved in Standards activities
with the AES, IEC and SMPTE while his other passions
include cricket, photography and folk music.
From 2005:
http://www.resolutionmag.com/pdfs/MAKER/chrisgaunt.pdf
Here's a 2007 article which details the history of AMS & Calrec mailnly. Seems they were involved with the BBC during the 70's and 80's, pushing through some great products with BBC's sound and broadcast demands of the time. I seem to remember that the BBC was pretty obsessed with sound quality in its recordings and FM/TV broadcasts. They even went so far as to design their own speakers (LS3/5a, LS5/8, LS5/9, LS3/6, LS5/12) because they felt there were no commercial types good enough and consistent enough for their stringent requirements.
Gosh, I just remembered - at the time, 1977-80's, those desks, if using IC op-amp technology, were previously using single or dual op-amps when the Signetics NE5532/5534 were introduced. Seems they were able to build a damn good product then, and now, and seems they have met with critical acceptance at the producer and recording engineer levels for the past 40 years.
http://www.ips.org.uk/files/07_Calrec_Enters_The_Next_Phase.pdf
Here's a gearslutz thread about Calrec consoles, and their use by recording professionals. Seems they had and have a good reputation, compared favorably to NEVE and the like. The commenters are working PROFESSIONALS in the recording and broadcast business, I suspect they do hear pretty well.
http://www.gearslutz.com/board/high-end/779-calrec-desks.html
Here's an ad for a fully refurbished 1989 Calrec console, I've copied a few things that make up the way the console is built and featured. What mrdbdigital is trying to say is that recording consoles are quite complicated and sophisticated tools, built up from literally thousands of active and passive component, each used to shape and create the final sound that the engineer, artist, and producer want on their recording and broadcast. At original cost of £100k to 300K new, they put everything they knew into the design and production of these consoles, and they had to sound good (even with miles of signal length and scads of signal devices) at the end. These don't get bought unless the end user (private or commercial) thinks they sound good and do the job that's required.
And remember, every recording out there is run through consoles like these, or newer fully digital desks. Sad to say also a lot of stuff is done strictly through computers and fairly rudimentary mixers/consoles at much lower price points (indie production for example) that may not have "audiophile" quality op-amps or devices.
http://www.cmlaudio.com/calrec-48-channel-m-series/
Control Area
From left to right, the console has 4 distinct control areas:
24 x PQ1895 Mono Mic / Line input channels (with improved microphony).
Main section with 2 Main stereo outputs, 8 x Stereo Groups, Aux Masters, Monitor Selector and Monitor Control
12 x PQ2588 Stereo Line Input channels.
12 x PQ1895 Mono Mic / Line input channels.
Channel modules have 10dB trim, Mic Gain +10 to -70dB in 5 dB steps. 32dB input headroom. Phase reverse. Parametric High and low pass filters. 4 band parametric EQ. 15 dB cut and boost, high and low Q settings. Bell or shelf setting on high and low bands.
7 Aux sends configured as 4 FB and 1 PA each with +5dB, on/off button, selectable pre or post fader.
PA muting by end fader end switch.
2 echo post fader.
Channel Separate output and insert selectable Pre EQ, Pre fader and post fader. 22dB output headroom.
AFL switch and PFL on fader overpress.
P&G faders (4220 Mono, 4222 Stereo – normal, push for on).
2 Echo return modules with bargraph meter.
Direct inputs with level control to Aux and main busses.
2 DL1656 compressor modules.
1 Oscillator module – variable tone and noise generator, ±12dB gain trim | +8dB to -60dB switched.
1 Calrec condenser talk back microphone.
3 dual needle Sifam type 74 PPMs with A / B, M / S and S+20 switching.
Comprehensive monitor panel with 24 Stereo and 24 monitor selector inputs, independent Control room, PFL, AFL and dim level controls. Independent cut left, cut right, cut both and dim. Mono to left, Mono to both. Phase reverse Right and Loudspeaker change over (L – R swap).
Reverse Talkback Loudspeaker.
Power
Power Supplies comprise:
2 x ZN1998 Audio, fan-assisted PSUs (3U).
1 x ZN1997 Logic, fan-assisted PSU (3U).
1 x ZN1705 Convection cooled phantom power PSU (2U).
Miscellaneous
On stand with deep script area.
Connectivity is via EDAC connectors. All balanced connections.
Full service manual and interface schedules.
► Additional information can be found in the Calrec M Series Outside Broadcast Consoles Sales Brochure »
http://www.cmlaudio.com/data/Calrec/Calrec-M-Series-Outside-Broadcast-Consoles-Sales-Brochure.pdf
