Old 05-14-2013, 06:12 PM
JonArts JonArts is offline
AK Member
John Boulton Signature Series installations used proprietary speakers (60 ohm). The amplifier isn't of much use without the speakers.
Phone numbers are the same Wiggy - probably the same guy.
worried about the 60 ohm issue, looks so good, down the street
Yeah, but four 16 ohm vintage JBL 10" drivers wired in series and them a high efficiency horn in parallel should put you close enough to the 60 ohms and you'd have tons of fun building those arrays!!!
Interesting..
JonArts is a one hit wonder???
I found this chain, now all I need is the bicycle!
That's the funniest thing you've ever said! :thmbsp:
I fall in this rabbit hole all the time.
That said, I'd buy these just for the chassis and switchgear, then put something good in it!
