tomlinmgt
Lunatic Member
Many have been mentioning the need for mobile absorption panels. I just built four of these and love 'em. Since my speakers often change so does optimum placement...which means first reflection point changes...which means where the panel is located needs to change. Portable panels make that a non issue. It also makes them easy to remove from the room in the event the SO is having a hard time accepting your dedication to achieving higher levels of fidelity and the moments of bliss afforded you by the panels' contribution to your bitchin acoustic treatment scenario.
Enjoy (click on images to enlarge)...
1x2 pine, muslin cloth backing, speaker grill cloth outer covering (burlap or muslin works great, as well), 2" OC703 (or 3" Roxul SafeNSound). Easy.
Screw frame together....
Add gussets to corners (I cut mine from 1/4" ply) or install metal corner brackets...
Cover with muslin cloth, staple and trim then set aside....
Lay panel covering material out and place OC703 on top and trim leaving about 6" around edges...
Set covered frame over 703 so the muslin cloth is making contact with the OC703. This non-nested method exposes all surfaces of the 703 and ensures absorption on the sides of the panel. If you use SafeNSound you'll have to nest it inside the frame (it's not as rigid and won't hold its form as good as OC703 so it needs the support of the frame)....
Now bring the excess outer covering up to the back of frame and start stapling it down. I like to start with the sides and staple from the middle out while pulling cloth to keep in taut. ..
Finished panel (which at this stage could be hung on wall, ceiling, etc.). I should note here the bumpy, irregular edges are not inherent to OC703. It looks like that because those panels I used have had the edges beat up from getting moved around a lot over the course of the last few years....
The stands are simple 1x2 screwed to the panel frame. You can use inexpensive pine or decorative hardwood and make them any length you wish. Bringing them up the full height of the panel would look nice...sort of a quasi-frame. The height of the panel at its horizontal center is set so that it's the same as my ears when in a seated listening position. The feet are cut from plywood and you can shape them any way you like. Decorative metal shelf brackets could be used as well.
Also, if you need to store the panels away when not listening you could "T" a piece of 1x2 to the bottom of the vertical "leg" and not completely tighten it down...just snug it...so that the foot can be swiveled (kind of like DCM did on the Time Frames). With that you can stack the panels one on top of another in a compact fashion without the feet interfering or protruding making them easy to store away when not in use...and effectively rendering your excuses for not being able to use acoustic treatments in your space because of WAF, existing decor, etc. to the realm of the irrelevant. :yes:
Done....
Here's a nested panel using Roxul SafeNSound. That's screen door screen on the back. The front will get trimmed out with quarter round to cover the edge of the covering material and staples. These are to be located at the rear wall so I'm not as concerned about the sides of the panels being absorptive. Stands for these could be constructed using a method like or similar to the one above.
Here's info on how to find the best places in the room to locate the panels....
http://audiokarma.org/forums/showthread.php?t=446798
- Michael
Sent from my iPhone using Tapatalk
Done....
- Michael
