Leestereo
I'm working on a 12AX7 preamp with tone controls and a cathode follower output. I've attached the schematic, its a modification of a small SE integrated amplifier that had trashed output transformers. I'm wondering if I implemented the cathode follower properly: I measured about 4V at pin 8 (against chassis ground) when I expected about to see about 100V. The preamp does function; I hooked it up to a solid state power amp (47kohm input impedance) and the quick listening test was fine.
