As part of the LED lamp project I decided to go all-out and fully restore my Marantz 2285B. I decided on Deoxit / ProGold treatment for the controls, and replacement of the caps in the entire preamp / amp pathway.
So here are some shots of the work - first, the insides of the receiver from above and underneath.
Top view, top row left-to-right: tuning capacitor, transformer, power supply capacitors. Power amp board runs down the right side with black heatsinks. Inboard of that is the relay board, also mounted vertically. To the left is the tuner board (brown PCB) and the long narrow green board below that is the array of switches. The lamp housings (beige) can be seen below that.
From beneath: the tone board is at the top (it's been freed from the front face by undoing the nuts from the controls). It's partially in front of the underside of the tuner board. Along the bottom we see the input selector switch (it's at the rear of the unit, normally connected to the front control by a long shaft which I had removed by this point); the underside of the transformer and PS caps, and the power amp on the right side.
