Record Cleaning Machine - a recent build
boojum
AK Member
Here's another RCM to add to the list of those built by AK members. I collected parts for this over a period of several months, then built it in a weekend. The box, platter, and securing knob are 3/4" baltic birch plywood, with the box finished in Wilson-Art charcoal laminate for easy maintenance. The motor is from an ice-cream machine and not reversible, but gobs of torque.
The vacuum is a modified 120v Dirt Devil hand-held unit, also with lots of power. It collects dirt and cleaning solution into a small reservoir housed behind the corner door seen in the pictures, which is easily removable to empty. The platter rides on 3 nylon rollers so downward pressure is not an issue. Cork strips on the platter keep contact of the dirty side of the LP to a minimum while providing good friction, however I will replace with rubber strips as the cork sheds small particles.
One switch controls rotation, the other vacuuming. The finished unit measures 14" X 13.5" X 9" - I wanted a stand-alone unit small enough for an equipment rack. I'm using 80% distilled water, 20% denatured alcohol, and 2 drops surfactant; a common formula found here and elsewhere. Works great.
Good stuff! You will be so happy with being able to deep clean your own records. The sound difference is amazing most times.
Do you mind sharing what mods you did to the vacuum? Mine is nearing completion but im trying to figure out the best internal vacuum.
