Here are the info on the caps:
C007 is the installed location, these are pricey caps, but if you hear either you won't want to be without. Listening through to see if the Jensen is worth the extra $$$ over the Mundorf.
http://www.partsconnexion.com/prod_pdf/mund_ag+.pdf
https://audio.jensencapacitors.com/public/dokumenter/4pole.pdf
. . . If I'm not mistaken, these capacitors are similar to the use of multiple capacitors in parallel in a power supply, e.g., instead of using a single 10.000µF capacitor, you use 2 x 5,600µF capacitors together. IIRC, in the mid-90s many high-end SS amplifier designers advocated exactly this approach, and it has now become common place in amplifier power supplies since then. With double the number of capacitors you halved the power supply ESR and the ESL. Of course, you can further decrease the ESR and ESL if you use more capacitors. . . .
Clean work as always Pat. I also change out carbon compostion resistors wherever I find them in this era gear. They have more electrical noise and can be off quite a bit in value and/or change later over time some more.
Pat, what is the white foam cushioning for?
My first thought was to keep its toes apart while the polish dried! Just for fun I'm going to guess some form of adhesive other than double sided tape was used to reattach the dial plastic. How'd I do Pat?![]()
ahh... very interesting in deed.
Thanks for talking about the 4-poles Pat. Think I've got something new to try.
