Actually, Phase Linear (often nicknamed Flame Linear) had much more of a reputation for self destruction than harming other components.![]()
Bob Carver wrote a very interesting article about his amplifiers that appeared in Audio magazine back in the 1970s. The significant difference at the time, if my memory is right, was that he used an unregulated power supply, whereas most others used a tightly regulated power supply. He explained that the unregulated supply resulted in large voltage swings and that as a result his amps could handle music peaks without clipping that were equivalent to much more powerful amps than even these already extraordinary amps. He argued well ahead of his time that large amps which did not clip sound better. I think the perception that Phase Linear amps damaged speakers came from people who drove them too hard, an amp that clips at the power levels that his amps could deliver is capable of damaging most any speaker. I also think that if the load on the amp was too low (as in low impedance - think double large Advents for example) and the amp was driven very hard that heat was potentially a detriment to their longevity, but that is only my opinion. In the interests of full disclosure I still own a Phase Linear 400, bought in the 1970s. Bob Carver used to bring his prototypes to the store where I worked while in college to have them tested during McIntosh clinics. This was before he started Phase Linear in the basement of the local A&P. Good guy, always thinking, always cordial and courteous to everyone he met.
Hi,Checking the outputs per the service manual turned up one shorted transistor. With it out of the circuit, initial testing tells me it has a reasonable chance of making sound again with a new transistor.
P.L.F. is that your gear in your avatar? Maybe post a bigger pic of your setup.
barkerd;... Definitely worthy of the effort to rebuild and maintain.[/QUOTE said:I have never looked into this. Can you help me learn where to find reliable people who perform this service?
be bridged?
Might want to check with Northwind - He's been playing with Phase Linear amps with Cap upgrades, new mainboards, LED lamps on the meters, and protection circuit from White Oak Audio.
Read an article where Bob carver stated the optimum power for these speakers 1250 watts a side. I bought a pair back in the day and loved them,this would give enough crank for them. I have always seen them being sold but the tweeters are always fried. I would like to find a pair in decent shape again. Yeah high end stores were selling them back then and telling them 250 watts was plenty,gee no wonder the tweeters were fried all the time,I had a friend who ran bridged adcom 555's and he was still frying his tweeters because he liked to listen to classical at deafening levels.Yes, but watch out the impedance... Min 8 ohms... -> link:http://www.audiokarma.org/forums/showthread.php?t=310160&referrerid=56853
There was also PL factory service bulletin on this topic with another approach but cannot find it at this moment. Generally they were suggesting a transformer connected to the inputs, as to bridge an amplifier you simply invert the phase of one channel. You may do this with a passive transformer. An unbalanced to balanced line level transformer was exactly the solution from Lynnwood PL factory tech support...
The transformer connection scheme is here:
http://www.audiokarma.org/forums/attachment.php?attachmentid=179424&d=1258205577
Putting a cooling fan is a must if you want bridging PL amps.
But besides theoretical possibility to go for the bridged mode - what for you'd need such power? PL amps are sensible to proper current sharing and additional stressing the output stage with mono conf may cause its unexpected failure. DC protection is then your only hope to save the speakers... If you had it....
