knockbill
Lunatic Member
This is on the 6L6 SE amp I'm building...
Have a scope connected to the speaker leads for a few days, to watch the waveforms... Put terminals on the bread boards today and when I hooked the scope back up, I noticed one channel has a solid "filled in" waveform, that appears as the VC is advanced, starting around 10 o'clock and then, disappears at around 1-2 o'clock.... (sorry for the tech talk, best way I can describe it!!)... I can't hear any distortion at all, the amp is dead quiet...Also noticed, if I put my hand between the output tube and the VC, the wave goes back to normal...
First thought it had something to do with the old VC I used to mock this amp up, but does the same thing with a new one....it does it with or without an input connected... Probed around, checked joints, changed tubes channel to channel,, changed CDP inputs, swapped scope leads, and can't find the connection to the "discrepancy"...
Voltages are good, there's no noise or static...
I'm sure the scope is telling me something, but I don't speak scope,,yet!!!!
Any ideas are welcome...
Regards,
John
Regards,
John
