hi, i see a log of bose 901 user here : )
i am building my new music system, and i bought the bose 901 VI ver2 as speakers. my trouble is, the 901s needs a active EQ hooked in the system, between pre amp and power amp, now i am buying the amplifier and DAC, and got confused...
the first option is buy NAD C375BEE with its MDC DAC module, safe option, since c375 is in 901's compatible lists. the only thing i am not sure is the DAC module, is it good? and it has only 1 optical input and i may need 2.
the other option is, buy c275 as power amp(same as c375, 150w@8oms per channel), and buy Cambridge audio Dac magic plus, as dac and preamp, magic plus has preamp function. the things i can't understand is, the output of magic plus is 2.1v rms(didn't see the max value), and c275's input sensitivity is 1.2v, that means, magic plus can drive the c275 to his max power rate, am i right? and what about i put the EQ between them? what would happen then? will the EQ change the voltage between pre amp and power amp? and makes the power amp can't put its power as expected?
i also noticed that, the C375's preamp part, output voltage could be 10v max, but the main amp part, the input sensitivity is the same as c275: 1.2v, why there is this big difference, my mean, in normal usage, the preOut and mainIn jacks are short-circuit, when the preOut output is higher than 1.2v, won't that bring "clipping"
