The HF-81 is one of the very first stereo amplifiers produced when stereo first came into being. A few were sold as factory built units, but being a product of Eico, the vast majority of these units were sold and constructed as kits.
The unit went through a couple of production changes over its run, most notably adding a 32 ohm output tap and more Function Selector options along the way, but other than these few changes, the unit remained largely the same from the first to the last units to roll off the production line.
True to Eico's design philosophy, the HF-81 has a lot going for it over many of the other low priced competitors of the day. It has a full array of input and switching facilities appropriate for the day, feedback RIAA equalization, ample gain, active feedback type tone controls, and a very good set of output transformers. And, it has that EL84/6BQ5 sound that has endeared so many. Eico always did throw the majority of a unit's cost makeup towards design features in the direct audio path. As a result, the HF-81 produces a sonic result that virtually everybody appreciates. However, as with all compromises, that means that other areas of the design did not enjoy the same level of attention. Just as Eico is well known for its audio quality then, it is equally well known for the hum and noise issues that often come along for the ride.
There are multiple issues that cause this problem over the whole of the Eico line, with the hum and noise components each originating from separate design issues. Thankfully, in the HF-81 however, the noise portion of the audible quiescent signal is fairly well controlled. On the other hand, the hum level is a different matter. Collectively, the hum and noise specification from Eico for the HF-81 is a bottom of the barrel -75 db below rated output, which the original unit can just barely meet with proper attention. However, pair this specification up with some sensitive 100+ db efficient speakers in a quiet room, and there's typically enough noise available to carry on a running conversation with. In my smallish 12 X 16 listening room, this was easily audible from my listening position. When it comes to high quality audio reproduction, any notable noise that does not originate from the original program source then must detract from the sonic presentation.
In some degree of fairness, I doubt that Eico ever considered the possibility that their little intro stereo kit would ever be paired with high cost high efficiency speaker manufacturers like Klipsch and Altec. After all, this was a kit designed to save precious consumer dollars, so big efficient speakers were virtually never a part of that equation. Therefore, the lower efficiency that typical speakers of the day had that this unit would most likely be paired up with would run interference to cover up a good bit of the noise. Today however, that scenario is often blown out of the water, where high efficiency speakers are virtually the norm now with lower powered amplifiers. In that setting, the hum issues the HF-81 become very apparent rather quickly.
The vast majority of the hum component can always be traced back to a minimalist power supply effort. And minimalist it is. Compared to the efforts that more up scale manufactures used to control it, the Eico has but a lowly single hum control to battle it, which only tames the most gross amounts of the stuff. But there is help that can make a solid improvement in the hum levels produced -- one of which also has notable other benefits as well.
So, this thread doesn't set out to retrace the excellent efforts of others before me regarding this amplifier, but rather, offers some fresh new input on areas I have not seen addressed with this unit. Therefore, the ideas presented can be applied to those units that have already had a good thorough makeover.
Stay tuned --
Dave
Stay tuned --
Dave
