Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Pioneer Audio
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 02-26-2006, 02:48 PM
foetusized
Guest
Posts: n/a
TX-710, the other early Pioneer digital tuner
I got my TX-710 in the post this past week. I purchased it via eBay for $20 plus $12 shipping, to add to my collection of SA/TX-x10 amps and tuners, sold by Pioneer as part of several packaged systems in the early 1980s. As far as I can tell, the TX-710 and the better-known TX-D1000 are the only Pioneer silver-face digital tuners. The photos below show both the TX-710 and the TX-610 it will be replacing (for now) in my bedroom system. If I ever get the new belts on my CT-F615, it will replace the TX-610 in the stack, probably below the SA-510 amp.
The odd thing about the TX-710 is that there is no way to manually tune in a specific frequency that I have been able to find. The two large buttons on the left scan up and down to the next station, but I can't find a way to get it to stop between stations. The display shows 0.05 MHz increments on FM, and 1 KHz increments on AM, and will often flicker up-and-down while locked on a station. The button on the far left is for FM local, and the other small buttons are for preset stations (seven FM, seven AM). The two switches on the right are for AM/FM and for FM mono/stereo. The third switch on the TX-610, not found on the TX-710, is for a tone generator to set recording levels. Both tuners are on the same station, but the dipole antenna is on the TX-710, so it is coming in stronger on its LED strength meter.
The big difference can be seen on the back. The TX-610 has a fiberboard back panel, with no external AM antenna; I have a cheap AM external loop I've been using with mine. The TX-710 has an external AM antenna and a voltage selector on a metal back panel. Unfortunately, both have hardwired RCA cables on the back. Both also have the same metal case on the tops and sides, and fiberboard bottom panels.
  #2
Old 02-26-2006, 03:06 PM
agger's Avatar
agger agger is offline
more Pioneers :-)
I think the frequency flickering on these early digital tuners is for the reason that they are in principal analog tuners with a digital frequency display and a frequency locking which regulates the selected frequency. If it swifts a bit you will see it in the display.
__________________
Pio:SX-450,690,737,770,780,980,1000TW,1250,5590, D7000,TX7800, SA7500II, SA510, 708, 710, 9100, 9900(broke), RT-707
Yam:CA810, CR820, CR2020, R2000, NS244
Canton Karat 60DC, KL-888S, CS-3000A
TD145-II+Glanz-MFG11
  #3
Old 03-09-2012, 08:14 PM
Rob.'s Avatar
Rob. Rob. is offline
AK Member
I just bought a TX-710 Tuner.
Do you use the 75 ohm or 300 ohm for your antenna ?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Parts Express
Meistertech Solutions
Capacitor World
AudioFriends
Analog Engineering Associates
Vintage Home Audio
Okki Nokki
Hudson Valley Hi Fi
Wargos Electronics
Organ Donor Parts
Parts Connexion
Sound Stage Direct
Take Five Audio
Audience AV
Howard Products
Simply Speakers
The Tube Store
FM DX Antenna
AudioClassics
Many Moons Audio
Audio Doctor
RSL Speakers
Yesterday's Audio
DeWick Repairs
BOI Audio Works
Politicalchat.org
MCM Electronics
Amplifiedparts
Videokarma.org
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
ęCopyright 2002-2015 AudioKarma.org, All rights reserved.
