I have a pair that the original owner gave me and they sound fine. Obviously, they need sufficent power, I think at least 60 watts is needed for most uses as well as a bit of distance from the listener (12 to 15 feet). One other thing that helps, I believe, is to cant the cabinets back a bit to improve the time-aliginment.
Having said that you could also mirror image the drivers as well as redoing the crossovers, but now you're looking at quite a bit more work and expense.
[Edit: The question was what to drive the AR3a's with, and of the gear I've heard with them, I believe that the mid-70's Sansui Integrated amps with 50-60 watts sound as good, or better, than anything else I've heard with them.]
However, one thing you'll probably realize pretty quickly, is how good the
AR3a were and how well they stack up against today's speakers!
:thmbsp:
Best Regards,
TerryO
