tyella
Last May I found a pair of Acoustic Research AR-1X speakers at a thrift. It turns out that these are pretty rare, so I thought I'd document my progress as I refurbish these for use in the home. The serial numbers are quite low and almost consecutive (20083 and 20086). Some of this information has already been posted, but here it is in one place.
Here they are after I brought them home:
I listened to them. One of the tweets wasn't working and the other was really scratchy, only playing with the wiper in a specific position.
First step was opening them up and seeing what I was working with. I'm not sure if this is yellow fiberglass or rockwool, but either way, it went into a bag for weighing. If there's interest, I'll reweight the bag, as I forgot the actual weight (it was approximately 36 ounces if I recall):
The crossover:
I checked the non-working tweeter with my multimeter, and it seemed fine. I bypassed the wiper, fired it up and the tweeter sang. I had trouble pulling the knob from one of the potentiometers (rheostat? I'm calling them "pots" from here out) because the set screw was corroded so badly. This was coincidentally the same speaker with the bad pot. That closed the deal for me. I purchased 2 replacements from vintage-ar. One pot came right out, the other set screw was still stuck fast, even after soaking the hole in liquid wrench for a couple of days. I had to cut the knob off with bolt cutters. The shaft is still fine and I retained the pots, just in case I want to refurb them and put them back.
I replaced the pots with L-pads from vintage-ar and bypassed the original caps in favor of new Dayton 5% polys. Rather than using hot glue or similar to affix the new caps, I drove a small screw through a zip tie. I think that should hold for some time.
I stuffed the cabinet with fluffy new fiberglass, but needed a new shroud since the old ones disintegrated when I removed them. I couldn't find cheesecloth, my first choice. While at Walmart anyway, I tried the fabric section. I found this light, airy backer material and purchased a couple of yards.
Here is the stuffing in place.Please ignore the funky wall of my basement. That's another story, but suffice it to say, there is no real danger of spousal encroachment in this part of the house. The funkier the man cave, the safer it is from co-opting.
Replaced the woofers and used some moretite caulk to seal them up. I had white, so hopefully it won't be visible through the grill cloth.
Tested the speakers and they sound just fine. I was in my basement using a home theater receiver that was specifically rated for the 4-ohm load, so critical listening will have to wait.
Next up, dealing with the scratched to hell surfaces. There were water rings, paint splatters and what-not. 220 grit sandpaper, Restore-a-Finish followed by Feed and Wax and they look pretty good. One corner is swollen thanks to (I assume) a plant on top. The veneer is wrinkled there, too. If I get a wild hair, I'll pull all of the veneer off, pull the corner together and re-veneer. On second thought, that would take several wild hairs. Maybe in a year or two if I run out of projects.
Here's the swollen corner:
The pictures I took of the wood refinishing have somehow vanished from my computer. I'll take more soon.
Next up is the grill cloth. Technically, the existing cloth is just fine. However, to be used in the real world (i.e. the wife's house), this movie theater carpet looking stuff will have to go. It's actually really cool cloth with gold thread woven throughout. I will pull the staples carefully and try to save it. What for, I don't know, but that's how I roll. It will probably get pitched in a couple of years, along with that box for the toaster I bought in 2009.
I plan to re-cloth the grill using this Charlescraft Irish Linen:
Here are the two side-by-side. The linen isn't nearly as groovy, but neither is our home decor, so linen it is.:
That's as far as I've gotten. I will hopefully attach the new cloth today. To avoid splitting the wood, I think I'll glue it and will pick up some adhesive today. Wish me luck!
The crossover:
