So how accurate are those smartphone sound measurement apps?
Thanks, that's really interesting. I would have thought that mic variation would be a killer, but getting within 2 dB is surprising and pretty darn good.
Thanks for the thread!!
I just downloaded the Sound Meter app onto to my iPhone.
Will have to give it a try when I get home.
Before reading the article, I guessed that they weren't very accurate. I use a free one for comparing volume levels from different sources. I figure it should at least be able to do that much.
These can be surprisingly good, but do need to be calibrated using a professional meter - without this the offset can be more than 10db
I have a couple ADC meters that have been calibrated. I compared it to the sound level meter App I had downloaded to my Samsung Gakaxie Note 4 and was surprised by the results. It's certainly close enough for the way I use it. For more critical applications I use one of my calibrated ADC units. The Radio Shack units aren't bad either. They're cheap and can be calibrated. At least the ones I have seen. I did buy one of their digital ones a couple years ago on closeout. Pretty decent
Looks like you might have to do a lot of trial and error to find a good one.
"A total of 130 iOS apps were examined and downloaded from the iTunes store*, of those, 10 apps met our selection criteria. A total of 62 Android apps were examined and downloaded, however, only 4 apps partially met our criteria and were selected for additional testing."
