Latest recap list for sx-1010
craxx6969
Well-Known Member
Good evening fellow AK'rs. I am looking for the latest recap list which includes the Bournes trimmers and all the trans for the 032-D board on AK. There are so many that do not have the entire list that is like looking for a needle in a haystack.
Can someone point to the latest one for me. I have tried for the last 1/2 hour and only find mattsd's.
Thanks in advance!
JT
These are the Murata:
VR1, MOUSER P/N: 81-PV36P202C01B00, Murata Trimmer 2K 0hms, (Quantity 2)
VR2, MOUSER P/N: 81-PV36P501C01B00, Murata Trimmer 500 0hms, (Quantity 2)
MTF's Bourns Trimmers Mouser P/N's:
awh-032 VR1 2.2K multi T 652-3296P-1-202LF
awh-032 VR2 470 ohms 1T 652-3386H-1-501LF
Use Bourn, VR1, sx-1010., search words. 5 minutes.
Thank you for the response. I will search for the 032 board additional transistors that are not listed in the recap list.:thmbsp:
I will post what I found, I did take some of them from a previous 1010 that I was working on. Once posted, it should be vetted.
craxx; Just how many transistors are on your awh-032 board??? Should be 12 each. I don't ever recall seeing a "D" revision board. Are you sure it's a "D" and not a "0"(ZERO)?
I've seen AWH-032 no suffix and ZWH-032-0 (ZERO) suffix boards before.
How about a list of transistors by position of all of them on the board.
Larry, there are two versions of that board. If you search AK using my name and 032 you will see my photos of the D version of the board. It is called another sx-1010 resto - page 9. Photos are therefor review.
Larry, most recap lists do not have every transistor on it. Only the ones that are known to be weak or troublesome. I choose to replace all but a few. For instances the two on the heat sink, q9 and q10, 2sa740 and the 2sc1448, I replace with 2sa940 and ksc2690 respectively. Q7 is a 2sd358 and I replace it with a c2690, q4 is a 2sb528 and I replace it with an a1381 and q8 is a 2sb528 which I replace with a 1220ay. Yes there are only twelve transistors but the list I have only has Q1,2,3 5 and 6 listed for replacement. The two left are Q 11 and Q 12 which I do not replace whe I redo the board. Hope this helps clear up the confusion.
awh-032 C1 0.68 25 cssa 667-ECQ-V1H684JL
awh-032 C2 1.5 25 cssa 647-UKL1H1R5MDD1TA
awh-032 C4 10 16 cea 647-UPW1E100MDD
awh-032 C8 330 6.3 cea 647-UPW1A331MPD
awh-032 Q1 2SA726 512-KSA992FBU
awh-032 Q2 2SA726 512-KSA992FBU
awh-032 Q3 2SA726 512-KSA992FBU
awh-032 q4 2sb528 ksa1220 / ksa1381
awh-032 Q5 2SC1451 512-KSC3503DSTU / KSC2690?
awh-032 Q6 2SC1451 512-KSC3503DSTU
awh-032 q7 2sd358 ksc2690
awh-032 q8 2sb528 ksa1220
awh-032 q9 2sc1448 ksc2073
awh-032 q10 2sa740 ksa940
awh-032 q11 2sc945 512-KSC1845FTA
awh-032 q12 2sa733 512-KSA992FBU
awh-032 D1 1S2473 512-IN4148
awh-032 D2 1S2473 512-IN4148
awh-032 D3 1S2472 512-UF4004
awh-032 D4 1S2472 512-UF4004
awh-032 D5 STV-3H X
awh-032 D6 STV-3H X
awh-032 D7 1S1885 512-UF4004
awh-032 D8 1S1885 512-UF4004
awh-032 D5 STV-3H X
awh-032 D6 STV-3H X
Thanks for the list and I'll double check my list. I may one or two listed incorrectly as compared to what I put in the board.
Thank you again for the list!
I listed an incorrect transistor on my response to Larry. I do have the 2073 installed in the Q9 position. Q11 and Q12 will be replaced with the ones listed 1845 and 992.
Thanks again to the master, MTF. Where in the world would we be without his knowledge and selflessness in helping out all of us on AK. :thmbsp:
Some may have the 032-0 board and some may have the 032-D board. My board is a D board which I will refer back to post #8. The D version removed a diode and replaced it with two jumper wires, lower right corner of the board.
So I would recommend checking your version of the board before replacing all the diodes as some are STV diodes as in mine.
Someone may chime in and let us know which version of the board the list belongs to.
Thanks again.
Every couple of years we go round and round on this board.
The "version" is a compromise that should cover them all.
Worst case the board doesn't have a D1, nor a D7 and D8. So you end up with 3 extra diodes... That's why I didn't go to 2x or 3x on the D7, D8 replacements...
It COULD also have stv-3 diodes at D7 and D8, which ARE LEFT IN PLACE if OK.
first, PLEASE be specific!!!
Thanks again.
PLEASE mention the number of the removed diode for precision, for those of us actually trying to track things down...
And what the jumpers are doing / where they are going would help too. I assume it's the d1 area you are talking about.
The 44 meg Hi-res manual doesn't even have internal consistency.
On the 12.7 power amplifier assembly (awh-032-0) page the schematic does NOT show the D7 and D8 diodes THAT ARE CLEARLY VISIBLE ON THE PC BOARD LAYOUT DIAGRAM RIGHT BELOW IT!!!!!
D7 and D8 when added were first 1s1885's, then were upped to stv-3 (NOT stv-3H!!) diodes for their additional voltage drop.
UF4004 x 1 each were subbed, but 2x or 3x UF4004 strings can be used as per Echowars.
The other changes are in the voltage divider strings that develop the voltages for the VR1 DC offset voltage adjustment pot.
First, there are versions without D7 and D8:
http://www.audiokarma.org/forums/showpost.php?p=2322349&postcount=301
On 1010 Power Amp Board AWH-032-0, I'm wondering why you replaced diodes D7 & D8, which were each originally a single 1S1885 diode (rating: VRRM 100 Volt, IFSM 66 Amp) with two Fairchild UF4004 (rating: Repetitive peak reverse voltage 400 Volt, Peak one cycle surge forward current 30 Amp) in series. This seems like less protection rather than more in terms of the current capability of the replacements. Am I missing something?
I attach ccheath's illustration of the components from his earlier posting and a pic of my original unmodified board.
Here's why, when I was working on Maddart's sx-1010, it had stv3's instead of 1s1885 diodes and one was bad.
then this (post 60):
http://www.audiokarma.org/forums/showthread.php?p=1494762#post1494762
explains EVERYTHING.
The D7 and D8 diode are there to prevent the driver stage from saturating the output transistors too hard. In this case, Pioneer originally thought 1 diode drop would do it, and evidently decided later that they'd like a little more breathing room for fools who like to get a bit too frisky with the volume control.
You do not need to find more STV diodes to replace the bad ones. If this were my own receiver, I'd replace the dead diode with a good, fast (*speed is important! 1N4004 or similar is too slow!), rugged 1A diode, such as a UF4004, and call it a day. But, do replace both D7 and D8 if you do either.
If this really bothers you, make a string of two UF4004 diodes in series ('A'-frame mode), and replace the STV-3 with it. I can't think of a way to do this with three diodes that won't look like sheeite.
*1N4004 - Trr = not specified, since it is designed to deal with 60Hz
UF4004 - Trr = 50nS
Then there is the change to "the lower right corner" DC offset voltage generator section.
There are versions (IIRC) where D1 is replaced with a resistor....
And versions where the diode d1 is just left open
and versions where the diode d1 is just left open AND R5 is shorted with a jumper.
Not to finally mention that the placement of the two STV-3H diodes were altered, from two on the driver heat sink, to one of the driver heat sink and one remotely mounted in the correct position on the OUTPUT'S heat sink.
