buffdriver
I haven't seen a thread on recapping the TX-7800, so I sifted through several threads and attempted to build a list of caps required by translating the part numbers from the service manual and by using the Mouser website. The CSV list below should import into Excel. Capacitors are listed in the order they appear in the Service Manual. Please note that this is NOT currently an approved or recommended list, but a starting point.
Edit: I have raised the voltage on some capacitors and corrected several entries that did not need low leakage caps.
Pioneer TX-7800 re-cap,,,,Nichicon UKL = low leakage,,
Part Number,uF,V,Svc Manual,Notes,Mouser Part Number,
Power Supply (AWR-183),,,,,,
Capacitors,,,,,,
C3,1000,25,CEA 102P 16,Increased Voltage,647-UPW1E102MHD,
C4,1000,25,CEA 102P 16,Increased Voltage,647-UPW1E102MHD,
C5,470,35,CEA 471P 35,,647-UPW1V471MPD,
C6,470,35,CEA 471P 25,Increased Voltage,647-UPW1V471MPD,
C7,100,25,CEA 101P 16,Increased Voltage,647-UPW1E101MED,
C8,100,25,CEA 101P 16,Increased Voltage,647-UPW1E101MED,
Transistors,,,,,,
Q1,,,2SD712-D,,512-KSC2073TU,
Q2,,,2SC945A-Q,,512-KSC2383YTA,
Tuner (GWE-111),,,,,,
C13,4.7,35,CEA 4R7P 35,,647-UPW1V4R7MDD,
C99,4.7,35,CEA 4R7P 35,,647-UPW1V4R7MDD,
C16,22,25,CEA 220P 16,Increased Voltage,647-UPW1E220MDD,
C32,3.3,50,CEA 3R3P 50,,647-UPW1H3R3MDD,
C57,3.3,50,CEA 3R3P 50,,647-UPW1H3R3MDD,
C98,3.3,50,CEA 3R3P 50,,647-UPW1H3R3MDD,
C34,10,25,CEA 100P 16,Increased Voltage,647-UPW1E100MDD,
C58,10,25,CEA 100P 16,Increased Voltage,647-UPW1E100MDD,
C66,10,25,CEA 100P 16,Increased Voltage,647-UPW1E100MDD,
C73,10,25,CEA 100P 16,Increased Voltage,647-UPW1E100MDD,
C83,10,25,CEA 100P 16,Increased Voltage,647-UPW1E100MDD,
C84,10,25,CEA 100P 16,Increased Voltage,647-UPW1E100MDD,
C36,100,25,CEA 101P 6,Increased Voltage,647-UPW1E101MED,
C39,1,50,CEANL 010M 50,Low Leakage,647-UKL1H010MDDANA,
C47,1,50,CEANL 010M 50,Low Leakage,647-UKL1H010MDDANA,
C50,1,50,CEANL 010M 50,Low Leakage,647-UKL1H010MDDANA,
C41,220,25,CEA 221P 16,Increased Voltage,647-UPW1E221MPD,
C68,220,25,CEA 221P 16,Increased Voltage,647-UPW1E221MPD,
C42,470,25,CEA 471P 16,Increased Voltage,647-UPW1E471MPD,
C43,10,16,CEANL 100M 16,Low Leakage,647-UKL1C100MDDANA,
C52,10,16,CEANL 100M 16,Low Leakage,647-UKL1C100MDDANA,
C53,10,16,CEANL 100M 16,Low Leakage,647-UKL1C100MDDANA,
C67,33,25,CEA 330P 16,Increased Voltage,647-UPW1E330MDD,
C48,6.8,50,CEANL 6R8M 50,Low Leakage,647-UKL1H6R8KDDANA,
C54,0.33,50,CEANL R33M 50,Low Leakage,647-UKL1HR33KDDANA,
C56,0.33,50,CEANL R33M 50,Low Leakage,647-UKL1HR33KDDANA,
C61,47,25,CEA 470P 16,Increased Voltage,647-UPW1E470MDD,
C63,4.7,25,CEANL 4R7M 25,Low Leakage,647-UKL1E4R7MDDANA,
C69,4.7,25,CEANL 4R7M 25,Low Leakage,647-UKL1E4R7MDDANA,
C64,47,16,CEA 470P 10,Increased Voltage,647-UPW1C470MDD,
C65,2.2,50,CEA 2R2P 50,,647-UPW1H2R2MDD,
C46,1,50,CEA 010P 50,,647-UPW1H010MDD,
C74,1,50,CEA 010P 50,,647-UPW1H010MDD,
C75,1,50,CEA 010P 50,,647-UPW1H010MDD,
C79,1,50,CEA 010P 50,,647-UPW1H010MDD,
C80,1,50,CEA 010P 50,,647-UPW1H010MDD,
C92,1,50,CEA 010P 50,,647-UPW1H010MDD,
C103,1,50,CEA 010P 50,,647-UPW1H010MDD,
C105,1,50,CEA 010P 50,,647-UPW1H010MDD,
C76,100,25,CEA 101P 16,Increased Voltage,647-UPW1E101MED,
C77,0.1,50,CEANL 0R1M 50,Low Leakage,647-UKL1H0R1MDDANA,
C93,220,10,CEA 221P 6,Increased Voltage,647-UPW1A221MED,
I know that it's delicate work to recap a tuner, especially as a first project. I actually bought a low cost beater TX-7800 to practice on before attempting on the "A-Grade" one.
If anyone has experience recapping this tuner, I would appreciate your looking over the list. Also, I would like to avoid a realignment, at least initially. Is there a reasonably simple rule of which sections of the tuner to avoid recapping? My initial plan is to start with the power supply board (to include the transistors listed) and move on to the tuner board, testing after each change to see if I've hosed things.
Thanks for any help you may offer. I'm not afraid to forge ahead, but I would like to avoid at least the most basic of mistakes. I will report on progress regardless.
BuffDriver
Capacitors,,,,,,
Transistors,,,,,,
BuffDriver
