WillVT
Here's the story. A few years ago, I was gifted a pair of Quad esl57's from my wife's uncle. He also gave me his Onkyo TX-4500, which he had used to drive the Quad's, I assume since new. I used this set-up for a little while, but was always a little nervous powering those delicate Quads with 60 watts of solid state. I also felt that while the Onkyo is a fine receiver, the Quads deserved better. So, I was on the lookout for a tube amp that wouldn't cost a fortune, like most of the amps people recommend for 57's do.
First, I found a Zenith tube console. I thought I could either strip out the amp, or just run the Quads from the amps speaker line out, as is. Here is the story of that.
http://www.audiokarma.org/forums/showthread.php?t=549438
Well, I realized that I would have to recap that amp among other things before allowing it near the Quads. Also, I felt it was it too good condition to gut.
So, I finally bit the bullet and got this little RCA rs177j console pull from ebay, at a great price. It was recapped and ready to go. I just put in better rca plugs, speaker terminals, and banged together a simple maple case. It uses two 6FQ7, four 6BQ5, and one 5AS4 tubes.
For the first few weeks, I had it hooked up to my Rectilinear III's, and boy did it sound great. It didn't have quite the punch of my Marantz 140, but at what I guess to be around 12-15 watts, it sure made the Rects sing. The sound is so three dimensional and smooth. I had heard that these amps have pretty low gain, so I'm definately pushing the preamp higher that usual, but there is plenty of volume at my listening level. I also finally get to see the meters on my SAE Mark 1M preamp actually move!
Yesterday, I finally pulled out the Quads and had a listen. So good! The quickness of these speakes, combined with the silky smoothness if the tubes, is just amazing.
So, it's another step in my audio journey. One that really has me smiling.
As a final note, is there anything I should know, as a new proud parent of tubes? Things like, is it bad to turn it on and off too much? Is it bad to leave it on for long periods? Anything I'm missing?
Thanks!
Thanks!
