M Jarve
Audio Geek and NGE Freak
The Wharfedale E –series was supposed to be the antithesis of “good, British” speaker design during its run from the late 1970’s and early 1980’s. The line more resembled the offerings of JBL and Cerwin-Vega than it did Rogers, or its Rank cousins. The E-series was built with primarily two things in mind: efficiency and speed. The “E”, after all, stood for Efficiency.
Fast forward 2 decades to the late 1990’s and early 00’s, and you see that the idea of the traditional British mini-monitor never went away, where as the E-series were enthusiastically praised in small circles of people in the know. At this time, I had an after school job working for a small, local hi-fi and HT shop that sold what were to most people in the area “high-end” gear: Denon, Wharfedale, h/k, Audio Source, and so on. At this time, Wharfedale had several product ranges, all equally as cluttered. In the high-end were the excellent Emeralds, and the low-end was filled with the Atlantics (the successor to Valdus). Smack in-between was the Sapphire line.
The top dog in the Sapphire line was the Sapphire 89 (SP-89). The Sapphire 89 is a 4-driver, 3-way system made up of 2x 6.5” woofers, a 6.5” mid-bass/mid-range driver, and a 1-inch soft dome tweeter. The bass drivers are loaded into a dual-ported cabinet with a single front port and single rear port tuned to different frequencies. The mid-bass/mid-range driver gets its own large, trapezoidal shaped, sealed sub-enclosure, which it also shares with the tweeter. The cabinet is extensively braced, but is unfortunately made up of only 5/8ths inch MDF. Due to the heavy bracing, it is very solid and “dead”, but you can see where costs were cut none the less. The front baffle is further reinforced by polymer trim plates around the woofers and integral tweeter wave guide. The edges of the front and side baffles are gently beveled and rounded to a nice effect.
The tweeters are slightly off-set from the center, and are typically sold in mirror-imaged pairs. The cabinets are labeled “L” and “R”, with the tweeters meant to be on the inside.
The cabinets are finished in either a black-ash or rosewood vinyl veneer. Although not by any means ugly, both finishes look sort of fake, and if you have the skill, you would be well put to re-veneer them in real wood. And finally, there is a grille that covers all the drivers, but leaves the front bass port exposed.
The cross-over is made up of two boards: one for the bass drivers, the other for the mid and tweeter. The system is designed with bi-amp capability in mind, and a set of double, gold-plated, 5-way binding posts are normally strapped together with a gold-plated, form-fit metal jumper. Cross-over components are good quality with air-core inductors and poly caps. Internal wiring is a little ordinary with 18 ga. stranded wire, but it is about par for the course.
Finally, I should mention that there were several different versions of the Sapphires made. The original version was made in G.B. and used the Wharfedale 1750 driver for the woofer. The second version was made in China (but still using British made Wharfedale drivers), and these can be I.D.’d by the use of a 1750H driver for bass (though some British made B-Stock units and replacement woofers were 1750H as well). Then there was the “True Blue” series that used blue-tinted woofers with a Wharfedale “W” embossed on the dustcap. These used a 1767H driver for bass. The units in particular I have are the original version, except I swapped out two of the 1750 drivers (one in each cabinet) with 1750H drivers.
The Sapphire 89 is an efficient speaker: actually it is the most efficient speaker I own. It is rated at 91dB 1w/1m, but I think that is conservative. I get satisfactory sound levels when the volume control is just above the point of 0. On the Mitsubishi, all that is needed is one click above -∞. However, the SP-89 can take 200-watts when needed. They are nominally rated at 8-ohms impedance, but measure about 4.2-ohms DCR. Sound is either true-neutral or 1 or 2 degrees cool from neutral.
The SP-89 must be very carefully positioned in the room due to having both a front and a rear port: too far or close to a rear wall, and you loose the lowest notes; too close or far from a side-wall and you loose lower mid-bass (80-150Hz). In my setting, they want to be about 16-18 inches from the rear wall, and about 18-24 inches from the side wall. Because of the offset tweeter, they do not require toe-in, but in my room and listening location it helped to have +/- 5 degrees of angle.
Listening to the SP-89 is a wonder. They look foreboding, but they are indeed balanced and very clean. No particular range overwhelms another, and vocals are exceptionally clean. The SP-89’s have tremendous energy and impart it on the sound, making the speakers disappear and putting the performance in its place. Alice Babs sang to me last night, not to a microphone in a studio.
Instant headroom is one of the features of the SP-89. Because of its good efficiency, even a mid-power amplifier, like a h/k 430 can go insanely loud without distress.
Now for some caveats:
Wharfedale did an excellent job with the big picture on this speaker, but it seems that in an effort to keep to its intended MSRP, they skimped on the details. The mid-range sub-enclosure, for instance, contained no dampening material. It is a veritable echo chamber in there, though the trapezoidal enclosure is supposed to negate that to some effect. The speaker had a certain hardness to voices before I filled it with fiberfill. Same goes for the bass enclosure. A single bit of batting on the bottom was all it had. I took the original bit and unfolded it to line the top and sides of the bass enclosure, adding a bit to the bottom and back. This eliminated the mid-bass “honk” that emanated from the rear port. The rear ports were held in only by friction fit. Putting a bead of mastic compound around the inner, external edge of the port sealed it up good and tight and holds it in place much better. And finally, the barrier between the bass and mid enclosure has wiring for the mid and tweeter going though it. It was sealed only be some brittle hot-glue. I filled up the hole with more mastic compound to provide a better seal. Just the small stuff like that elevated this speaker from a “good for the money” level to a “sounds twice as expensive” level.
The second issue (not an important one to me) are the flimsy grilles. The pegs have a bad tendency to break-off in the sockets, requiring you to drill them out if you ever want to access the internal workings of the speakers.
And finally, and this really just nit picking, is that because of the polymer trim around the drivers, you have to remove 8 screws to access any single driver. Tragic, I know.
So, is the SP-89 the second coming of the E-series? They are efficient, and they are energetic, but no. There can be no replacement for the E. However, the Sapphire 89 is a worthy, modern interpretation, and a very capable speaker on its own. :thmbsp:
