skillace
After flipping through a couple of restore/recap projects in AK I'm starting a new thread for a service & upgrade project of my recently acquired Marantz 1250.
Hope I can get much help and advice from the fellow members who have done it already.
I'm from Singapore & the amp has been bought and shipped from Australia a couple of weeks ago. I've been looking for one for some time and finally pulled the trigger on this clean looking unit. My brother helped me with the deal & shippment to Singapore. I'm very happy to have it as it's (vintage amps, especially Marantz) a very rare commodity here.
Initial findings:
The unit is pretty clean inside and out.
As I opened up the covers one by one, a few things caught my attention though!
1) The original big dual core filter cap has been replaced with two Nippon chemicon 12000uf 71v filter caps tightly squeezed in the original metal clamp.
2) It seems the 680uf 80v & 220uf 63v caps (light blue) on either side of heatsink on the power supply board has started showing signs of leakage.(as far as I can see no other caps has been replaced in this unit except the filter cap)
3) There's some signs of soldering works at the wire connecting pins on pcbs.
4) But when I removed the bottom cover actually surprised to see some totally careless repairing works done. I've a few melted wires (those soldered to the main filter caps) at the bottom.
5) As the unit is already in working condition, I've powered up the unit and started listening to it for first time.
A couple of things which I've noticed while playing music is only the left channel is working fine and the right channel is muffled. If I increase the volume the right will have something but still too low. After playing like this for more than 30-45 mins the right channel slowly comes alive. But the following day when i powered up the unit and started playing music happened to press tone deactivate button and the right channel suddenly came alive and played in stereo. So I tried pressing the button again and there goes the right channel again dead!
Now, I can listen to it in stereo with tone deactivated!
6) While switch off the power button, there's a nasty popping sound from the speakers.
Apart from all these troubles, the kind of sound it make is super addictive.
It's really mellow and has a very defined soundstage ( the instruments are not mixed up).
I've also hook it up to the TT via phono inputs and the sound it makes is not as enjoyable as the other sources.
My PM6004 sounds better in this department and I enjoy listening vinyl too.
But in comparison, 1250 sounds very thin and bass shy playing vinyl.
I hope a proper service and restoration, probably I call it an upgrade ( as I can't find the original components anymore) will make it a fantastic piece of equipment which I can keep for very long time.
I seek all the help I can get from the AK members who have done the restoration previously.
My intention is to prepare a parts list n place the order before going to the work station and strip it down.
I'll include some pictures in the following posts...
Dear frnds, What do you say?
Initial findings:
