Altec 886a
kfa888
Addicted Member
Anyone heard these? It a 10" two way with passive radiator. One 10" driven woofer, one 10" passive radiator and a tweeter per cab. Looking for opinions on sound. I can get a set locally for $20, all drivers original and perfect but the cabs are water damaged on the bottom.
Thanks.
Yeah, I got that much just looking for sonic impressions of them. If they are still there tomorrow I'll snag them. I could go get them now but I'm not really wanting to fight rush hour traffic to do so.
On a side note: these will make a great addition to my 2 way / passive radiator shootout as I have Genesis II's (8" woofer, 10" passive and a tweet) and the EV Interface II's (same config and general size as the Genesis II's) and possibly these Altecs.
I would snag them for that price I got a pair a couple weeks ago. I replaced the tweeter and they sound pretty good. Good luck
Were the tweeters bad or did you just not like them? What would you compare the sound to?
The tweeters that came in mine werent orginal to begin with and the surrounds were starting to go so I replaced them with a peerless tweeter from madisound for like 25$.
I think they sound awesome. I dont have a ton of experience though. The bass is pretty good. It lacks in the very low bass. I havent listened to a ton of speakers, so I dont have anything to compare them to.
They do sound better than my genesis 1's and athenas as-b1's. I hope that helps a little. I think a couple other members here have a pair. Good luck.
Dolan
The 886A should not have foam surrounds on the tweeter, so sniperdolan probably did not have original tweeters. They use a 2.5-inch CTS phenolic ring tweeter; Pioneer made new tweeters for these (or very similar ones) up until just a couple of years ago; they may yet still.
Sound-wise, they should be pretty neutral. Not overly warm like Advents, but not as cool sounding or as brilliant sounding as other west-coast speakers. Call it a "mid-west" sound, if you like. They are a bookshelf speaker, and are meant to perform in a horizontal orientation, but being that they use a cone tweeter, they will probably work well as small floor speakers or stand speakers in a vertical orientation.
I have the big-brother Altec 890C (single 406-8Y woofer, a 406-8Y sans motor for the ABR, and a CTS horn) , and they are the only speaker to have stayed consistently in my lineup for a year. That should say a lot unto itself. They go plenty loud with modest (30-60 watts) power.
For $20, you cannot go wrong with any working Altec. Tweeters (OEM CTS or Pioneer units) are readily available, and the woofers are fairly bullet proof if you keep within their specified power limits. Change out the x-over caps if you are so inclined, but you may find thry sound just fine with no modification at all.
I believe Theodoric has a pair. If you PM him I'm sure he'd be happy to give you a complete review.
cubdog
Jarve---I think the mystery horn in the 890C is a Heppner, it looks like other Heppners and DJK thinks's it's a Heppner.
If you've any information on the mystery horn I'm all ears.
I now use mine as a PA, play electronic drums and digital piano through them.
While I have not given them a thorough listening to they do sound very nice, I also have a pair of madera's which is the bolero W/O the passive radiator. When I can get to them I should try them stacked as they are a pretty close match and will probably sound fantastic together. The 886's will more than likely be my first try at veneering because they look like ass right now.
