My homebrew Record Cleaning Machine
Andyman
Scroungus Stereophilus
Well, after brainstorming for a few months, it's close to done. It works quite well, and all thats needed is to finish the base and perhaps install a limiter on the vacuum wand to control height and torque deflection.
It's the usual velvet wand and vacuum cleaner rig, but I wanted a power table similar to Grumpy's VPI,and that's what took the time. I tried a Pioneer belt drive TT I had here, but the vacuum was too strong and locked onto the record and stopped the table. I experimented with a bleed off valve to regulate the vacuum, but wasn't satisfied. I needed more torque.
Obviously a Harley 74 engine wouldn't fit and would be too noisy, so I started looking for low rpm motors that maybe suitable. Windshield washer, microwave, even checked Ebay for "gearmotoer", but them I found the ice cream maker. I figured if it had enough guts to move a set of vanes through some thick ice cream, it could spin a few records for me.
I had planned to use one of the Dual TT platters I have here as they already have a small gear on the bottom, but that presented step down ratio issues. I switched modes and cut a disc from some 3/4" Melamine I had here and used it. Cut off the lip on the cover of the ice cream container and screwed it o the bottom. Drilled a hole in the center and used a 2" long 1/4" brass screw as the spindle and a quick release knob from Rockler woodwooking for the clamp and we were set. Vacuum power is from a 5.0 hp Eureka vac I snagged out scrounging last summer. I also used a 12" turntable from Rockler as a sub base to support the platter while scrubbing. Initially, I bolted it to the base and platter, but it wasn't centered properly and bound. Now it's bolted only to the base and platter has some wiggle room. While the base is fairly big, I was able to fit the vacuum, plumbing, and a set of toggle switches into it, so it is a complete package; no need to stck a vacuum hose in the side; it's built in.
One of the nice features with it is that I found a nice device for the wand. I'm not quite sure what it;s called, but I believe extension coupling might be appropriate. It's a stock plumbing fitting at Lowes and runs around $3-4. It's a PVC fitting that has sliding tubes with O rings that allow you to move it in out and all around. With this fitting you can pivot the wand onto the platter and adjust the height up and down. Very nice.
So far it seems to work just great. Torgue is NO ISSUE as the motor just bulls that disc around. The vacuum does well too and runs the LPs dry. It seems to clean very well too. I'm using a Nitty Gritty wet brush with a homebrew solution, and it cleans up very well. Problem is that I'm finding that there are still quite a few surface marks and an unusal "spotting" on some records that isn't simple dirt, but apparently actual scratches. Plus many of my scores seem to be well used and heartily partied, so even clean they still have pops and clicks.
So what was the damage? Let's add it up.
Ice cream maker for motor $12.99 thrift store
Eureka vacuum $ 8.00 garage sale
Electrical switches $ 8.00 Lowes
PVC parts $ 12.00 Lowes
Wood, wire,hardware Shop leftovers
Velvet One of my daughter's old dresses
Nitty Gritty Brush $29.00 Delivered from Jerry Raskin's
So for about $40.00 or so bucks out of pocket, plus $29.00 for the brush (OK, I splurged, but I wanted something better than the cut back China bristle paintbrush I was using) you can make a very respectable RCM that does a more than decent job of cleaning up the gunk from your grooves.
Is it a VPI, probably not, but I'll bet the VPI doesn't get records 10x cleaner either.
No to paint it and fit a cover plate to the top and start in on all those LPs I've scrounged the last few years.............
Very nice job Andy. Will be most interested in hearing your observations on how well it works versus your old method.
Neither could I.
It sure beats my old Discwashers all to pieces.
Weighs about as much as a hundred of them though! :lmao:
NICE!!!!!
One of my "projects" on the burner also... Been collecting odds and ends and one of these days....
What were you using to clean prior?
You answered while I was posting:)
I am of the "spin-clean" crowd and will get up to the DIY RCM one of these days:)
I do mine in the kitchen sink with $.02 worth of Dawn, the rinse sprayer, and a couple of those really soft lint free Viva, Select-a-Size, paper towels to get them squeeky and dry.
I've seen that beast in person, and it is impressive!
Great job andy!
(now that I've stold some ideas from yours maybe I can make mine)
I thought about that, but always worried about getting down into the groove and wetting the label.
After Grumpy demoed his VPI, I was very impressed and decided that I could make something functionally similar with a bit of parts bin ingenuity. The motor was the hardest part, but once I got that ice cream maker, things took off.
It's always fun to build something that serves well. This is my homebrew machine. The label is safe and I can let the LP soak if it has a lot of moldy spots. I've let LPs soak for 1/2 hour while I did other things. If the brush and sprayer can't get the worst jammed in rock out, nothing will. I've used this on my already clean and quiet LPs to test the method and they come out the same as they went in. If you can drag a pointy diamond through the groove, you can brush it with a soft fuzzy nylon paint brush. Unfortunately, we all need something to fix already damaged LP's more than we need another cleaning machine.
That's sharp Andy, I am especially impressed by the wand which is where I've been getting stuck with mine since day one. Good goin!
Nice job Andy and great idea for the wand. I was going to build one of these and was going to pony up for the VPI wand assembly but this looks just as good.
Andy what keeps the platter from wabbling while you vacuum? Nice job by the wat, Iwould like to try to build one soon.
Heck of a job, Andy.
Still, Dawn and what is that, a paintbrush, looks cheap and easy. More my technical speed.
It appears that the ice cream maker motor is the thing to use. that's what jimmyneutron used in his also. Seems kind of a shame, I like ice cream.
