Greetings,
I started a thread a while back asking about peoples thoughts regarding amp channel separation and it's relation to imaging. I suppose that I worded it poorly or it was just regarded as too dumb to comment on but I never got a single response.
Forgive the rambling approach, I'm getting to the point shortly.
The last year or so I've been using a Onkyo DX-6900 cd player (90db channel separation) and after a lot of tweaking found that my speakers with my Yamaha AX-1090 (65db channel separation) gave the best imaging with the speakers toed in till they just slightly crossed in front of my listening position.
Earlier this week I swapped out the Onkyo cdp with a Denon DCD-1290 (110db channel separation). Aside from the (to my ears) much better detail I was surprised to hear that imaging was worse than with the Onkyo at first. I've been tweaking the speaker toe in and am now at slightly outside of center on my listening position and have achieved imaging that's at least as good as before. I'm hoping that over the next week or so I'll be able to get better results with more tweaking.
So I'm really curious to hear other peoples experiences regarding their speaker placement in regard to their amps and source devices, thoughts on device channel separation and how it effects their speaker placement, and if you have had similar experiences concerning needing to adjust speaker placement after changing amps or source devices.
Further in that direction, I'm also interested to hear about your experiences regarding the above and how (if at all) it changed as you did room treatments. Did adding room treatments lead you to need to change your speaker placement and or toe in?
Thanks for your patience with my long winded questions,
James
edit: Darn it, I spelled Channel wrong in the thread tittle.
edit 2: I should have added that my speakers are almost perfectly on the golden triangle in regards to spacing L-R and listening position, and are about 7 feet apart/in front of me.
James
