Copa1934
My ears are bleeding
SA-8800, for a song...well not exactly...
I can't sing, but you know the old saying. I had to drive a bit, 135mi round trip, but hey, it's a Silver Face!
So, first thing I noticed? She was dirty. And how. But typical for such vintage equipment. I took pictures, before and after. Like many digital cameras mine will fire a burst of images and write them in it's own good time. While the images were writing (I didn't care too much how they turned out) I turned my focus to disassembly. I got the "hood" off and found cob webs inside. Wow, fortunately the swatters moved out so only had to blow out the webs. But before doing that, more images. WTF? ER.... Issues with the camera. Dang. So proceeded to clean, forgetting I could have used my phone for more images. Doh!
Anyway, after a good liberal cleaning, using electronics cleaner to loosen the "stuff" caked on the boards and components, then blowing out, then using a cloth for wiping down the larger components, the inside looked good. Yes there will be images coming. So next I washed the face plate, the knobs and whatever else needed attention. I then cleaned the top and have her all back together.
How does she sound? Well let me tell you, she doesn't. I picked her up Saturday, cleaned her up Sunday, carried her upstairs this morning, and realized I haven't a freaking place to set her up. Dang! I have to move some things around, and remove one or two receivers. Once done I'll test with cheap speakers, first, to make sure all is "safe".
Only thing left to do is find a knob. Last owner must have lost one at some point and stuck something on that works, but also crimped the split shaft, so I'll have to open that up, gently, for when I put an appropriate knob on.
Oh, how does $60 sound? $10 in fuel, so $70 total. I'm confident she'll work fine. No odors to speak of, not components looked damaged or bad. Surprisingly the knobs all operated like new, unlike all the receivers and amps I've owned, which were stiff and "sluggish" if you will.
