Fred Longworth
audio fanatic
I own a repair shop, so I see the casualties.
Though premium speaker wiring and interconnect cables DO sound better, there are some serious hazards. One I encounter almost daily is DEATH GRIP AUDIO CABLES, hereafter known as DGAC.
A DGAC has a plug that grips the RCA jack so tight that sometimes when the cable is pulled out the jack comes with it, and all that's left is a plastic stub. If the ground portion of the jack survives, the point on the circuit board inside the set where the jack solders is likely to tear loose.
A DGAC has an enormously long barrel on the plug, which provides an extended lever arm. This also tends to tear the backside of the jack loose from the pc board.
A DGAC has super-stiff shieded cabling. Think of rebar.
A DGAC is often very short, and so never can take the safest route from point A to point B. No, everything must be under tension. Think: turnbuckles or clotheslines.
A DGAC has a wide, fat plug, so that if the jacks are closer together than normal the plugs will bump into each other, forcing the plugs to go in at an oblique angle.
A DGAC is plated with Krytonite so that even Superman himself won't be able to pull them loose.
If I try to share ANY of the above points with a typical DGAC owner, s/he will often put hands to ears. Think: hear no evil.
Fred Longworth
StereoTech Classic Audio Repair
http://www.repairaudio.com
Fred Longworth
