Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Thinking Out Loud
We appreciate your help
in keeping this site going.
FORUM RULES
Reply
Thread Tools Display Modes
  #1
Old 08-11-2006, 12:04 AM
Bigerik's Avatar
Bigerik Bigerik is offline
Super Moderator
Intelligent Chip GSIC-30 test info and reviews
Intelligent Chip GSIC-30 (treats up to 33 CDs, DVDs or SACDs).
Machina Dynamica now carries the amazing Intelligent Chip, an emerging technology device that improves CD sound quality in the blink of an eye. The Intelligent Chip is a thin, 1-inch square orange wafer that automatically upgrades any CD/DVD/SACD disc when the Chip is placed momentarily on the top surface of the player while the disc is playing. The sound of the upgraded disc more closely resembles the sound of a remastered version -- with less congestion, more information, greater dynamic range and more air! The disc upgrade is virtually instantaneous - and is permanent.
More info is available at MD's website at: http://www.machinadynamica.com/machina64.htm
Signed up for this one are:
1) Gary P
2) Arm013
3) Ozmoid
4) Holst
5) Army
6) Tedrick
7) Negotiableterms
8) Sansui Louie
9) Grainger 49
10) ChrisF
11) Dnewma04
12) Theodoric
13) Tonedeaf
Again, anyone missed here?
__________________
  #2
Old 09-07-2006, 11:45 PM
Grainger49's Avatar
Grainger49 Grainger49 is offline
AK Member
We better keep a CD/DVD/SACD count on this one. Looks like the limit is 33, and as written, "Up to 33CD/DVD/SACDs," it could be less.
__________________
"Remember, you are the only one who needs to like the sound of your system."
Grainger Morrison
  #3
Old 09-10-2006, 07:13 AM
geoffkait geoffkait is offline
AK Member
Notes on Intelligent Chip: The Intelligent Chip is capable of upgrading 30 to 33 or 34 discs (CD,SACD, DVD), provided care has been taken to prevent loss of "power" of the chip. To maintain longevity of the Intelligent Chip, the orange wafer should always be stored in its plastic case when not in use. The plastic case contains thin sheets of clear polycarbonate that help shield the active material inside the orange wafer from infrared light (produced by laser of the player, sunlight, even room lighting). Also, the chip in its case should be kept a safe distance from the CD player when not in use.
To upgrade a disc, remove the orange wafer from the plastic case and place the orange wafer on top of the CD player above the transport section. Insert disc to be upgraded into player and push "PLAY" - allow disc to play for about 2 seconds. The disc will then be fully upgraded. The orange Chip can be left on top of the player if you wish to continue upgrading additional discs; otherwise, remove orange wafer and return it to the protective plastic case.
  #4
Old 09-10-2006, 09:11 AM
Huck Huck is offline
AK Member
Hi: I am on the list for the Clever Little Clock and I was wondering if I should
be using the clock together with the chip to benefit? Thanks, Huck
  #5
Old 09-10-2006, 09:18 AM
luvvinvinyl's Avatar
luvvinvinyl luvvinvinyl is offline
Administrator
Huck, just so you know, for the purposes of this tweak test and review, Bigerik has requested that reviewers only use one item at a time, so that any changes that you hear can be directly and definitely attributed to the item in question. I'll let Geoff answer the question wrt your own system, after any testing.
__________________
Let us not look back, in anger, nor forward, in fear, but around, in awareness.
Audiokarma
  #6
Old 09-10-2006, 09:30 AM
AK Member
Sorry! I do recall reading that, Thanks,Huck
  #7
Old 09-10-2006, 09:33 AM
Administrator
No problem. I'm sure that Geoff will still answer your question, when he returns.
__________________
  #8
Old 09-10-2006, 10:02 AM
AK Member
Huck - Bigerik is correct, the items sent out are (1) mutually exclusive (i.e., operate independently from each other) and (2) for test purposes should be evaluated one at a time.
WRT your general question, the answer is yes, the clock and a chip-upgraded disc should provide sound quality beyond either one alone -- the reason I say "should" is that results for any item under eval can vary quite a bit from system to system for any number of reasons. I.e., they are not "silver bullets."
~ Geoff at Machina Dynamica
  #9
Old 09-10-2006, 10:48 AM
GaryP's Avatar
GaryP GaryP is offline
AK Member
Thank you! I was worried about "over upgrading" or somehow wearing it out before I sent it to the next tester.
I have been considering what CD to select and I think it should be a CD that I have two of. Something that I really like, is well recorded and especially well mastered. Hmmmm, I have a few to choose from....
Geoff, does this make sense to you? Any other suggestions?
__________________
"Never regret. If it's good, it's wonderful. If it's bad, it's experience."
--Victoria Holt (1906-1993) best-selling British novelist
  #10
Old 09-10-2006, 11:25 AM
AK Member
Gary, you make a good point, since once you've upgraded the CD you cannot go back and listen to it as it sounded before treatment. You could select a CD you're very familiar with, one that you've listened to a lot before using the IC. Then, the effect of the chip should be easier to hear. As you suggested, another good approach is to have two identical discs - say two that were burned from an original CD. Then you would be free to A/B until you "keyed in on" the IC's effect. (This is how we demo'd the IC at CES last year.) Also, you can make the test blind, if desired, using the 2 identical CD scenario.
~ Geoff
Audiokarma
  #11
Old 09-10-2006, 01:50 PM
Grainger49's Avatar
AK Member
Quote:
Originally Posted by GaryP
. . . or somehow wearing it out before I sent it to the next tester. . . .
Wouldn't that make it a strong suggestion for testers to make note of the numbers of disks that were upgraded? With a maximum of 34 disks, the number could be exceeded before the end of the list is reached.
Not to mention, those who are not careful about replacing the chip after use will reduce the maximum number of disks that could be upgraded.
__________________
Grainger Morrison
  #12
Old 09-10-2006, 03:32 PM
AK Member
To Group - There is now a more effective and more reliable method for using the IC. While the IC on top of the player method is OK and usually produces good results, I feel this new method is superior and more reliable.
Machina Dynamica's Special Method for Using the Intelligent Chip Inside the Player
1. Pop open the orange wafer with a razor blade or thin knife blade.
2. Remove the thin green sheet 1"x1" with 3 small metallic dots in the center. The GSIC-30 contains 3 silver dots located in the center of the green sheet. (The GSIC-10 contains only 1 dot)
3. The green sheet w/ dots will be placed on the inside "lip" of the CD tray, directly below the CD to be treated; thus, the green sheet with dots will be INSIDE the player when the CD to be treated is playing.
4. Open the CD player drawer and place the 1x1 green sheet on the recessed inner lip of the CD tray, shiny side of the dots up. To prevent the green sheet from falling into the inside of the player when you play a CD, use clear Scotch tape to hold the green sheet to the inner lip of the CD tray. NOTE: The green sheet cannot be allowed to interfere with the operation of the transport spindle, and can be trimmed a bit on all sides to around 3/4 x 3/4 to avoid the possibility of contact with the spindle mechanism.
5. Place the CD to be treated on the CD tray as usual, covering the green sheet.
6. Play the CD for one or two seconds. The CD is now treated. You can keep the green sheet in place on the CD tray and continue to treat additional CDs, or remove the green sheet and return it to the Protective Plastic Case.
Regards, Geoff at Machina Dynamica
  #13
Old 09-10-2006, 03:59 PM
GaryP's Avatar
AK Member
That method seens scary to me.... the old method still works, right?
__________________
  #14
Old 09-10-2006, 04:08 PM
GaryP's Avatar
AK Member
Yes - I will include a tracking sheet with the I Chip. Everyone should initial and date it* so we can see when it "expires".
Gary
* Dating the IC is just for curiosity purposes....
__________________
  #15
Old 09-10-2006, 04:09 PM
AK Member
The original method is still effective in most systems. Just not to the degree of the new method.
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
AudioClassics
Grant Fidelity
Turntable Depot
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
Audio Atlanta
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
McIntosh Cabinets
Zebra Cables
Radio X
Venus HI-FI
vancouver audio speaker clinic
MCM Electronics
Politicalchat.org
Videokarma.org
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©Copyright 2002-2009 AudioKarma.org, All rights reserved.
