Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Dollars and Sense
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 08-27-2006, 11:42 AM
Tripqzon's Avatar
Tripqzon Tripqzon is offline
AK Member
Pioneer PD-M90X
Anyone out there own one of these. http://cgi.ebay.com/Pioneer-PD-M90X-...QQcmdZViewItem I would like opinions, etc whether good, bad or indifferent.
I was high bidder on this model. It is the Reference Series version. It is a non functioning unit. Hopefully it can be repaired at reasonable cost.
Thanks,
Paul
__________________
Carver C-1,Carver M1.5t,Carver TX1-11,Pioneer DV-47A,Pioneer PD-M90X, Pioneer F-91,Pioneer CT-F950,Pioneer PL-518, Pioneer HPM-100,Shure V15 Type IV,Nakamichi CR-2A
  #2
Old 08-27-2006, 02:43 PM
Blue Meanie's Avatar
Blue Meanie Blue Meanie is offline
Scratch 'n' Sniff
Location: Where No Man Has Gone Before: The Planet Phi-Epsilon Nudist Colony For Women
I think you meant the ELITE series...
Jeff
__________________
Time is an abstract concept created by carbon-based life-forms to monitor their ongoing decay.
4 out of 5 cannibals agree: Vegetarians taste better.
  #3
Old 08-27-2006, 03:06 PM
Tripqzon's Avatar
AK Member
Quote:
Jeff
OOPS!! You're right. Thanks.
Paul
__________________
  #4
Old 09-01-2006, 07:27 AM
Bogframe's Avatar
Bogframe Bogframe is offline
www.bogframe.com
How did you do the wood sides on your timer and cassette deck? I just got a DT-510 and a CT-F850 for my bedroom rig and would love to have them match the SA-5800 and TX-6800.
__________________
Save your memories before they fade away!
  #5
Old 09-01-2006, 08:03 AM
redd6054's Avatar
redd6054 redd6054 is offline
AK Member
Hi I have one of these players, it sounds very good. Mine also was purchased of ebay, non working. I was correct in assuming that it was the laser, and had it replaced. More expensive than the normal laser replacement as pioneer charges a premium on Elite parts. I believe that todays upper end DVD players give a sound as good or better as this unit because of technology moving forward.
cheers Wolfgang
__________________
Fast 5.0's rule. Listening to records!
SX5590,5560,1080,1010,3800,838,spec1,2,4,SA7700,91 00,TX6700,9100,D1000,RT707,909,SG9500,CTF1000,9191 ,
Audiokarma
  #6
Old 09-02-2006, 10:32 AM
Tripqzon's Avatar
AK Member
Quote:
cheers Wolfgang
Thanks for the input. I'm hoping it's not the laser. The seller does not specify what is not working. I don't know if it even turns on. Maybe I'll get lucky and it will be a power supply issue or bad fuse.
Out of curiosity, how much was the laser assembly?
Paul
__________________
  #7
Old 09-02-2006, 11:17 AM
Tripqzon's Avatar
AK Member
Quote:
The cassette deck was easy. I had the wood cabinet already so all I had to do was strip the vinyl off and applied a red oad veneer that I purchased at Lowe's. It was Band-It brand iron-on veneer. I also purchased the edge trimmer but discovered that the edges can also be done with a utility knife with a sharp blade. If you're new to this as I was, I would highly recommend the edge trimmer. I used 220 grit paper to complete the edges after the cabinet was completely veneered. One thing I learned was that I got better looking results by veneering the sides first and then the edges. If you don't have a wood cabinet for the 850 I would ask around AK for someone that has an 850 with the cabinet and get measurements and pictures. They do look really sweet in wood.
The timer has since been redone because I saw too many flaws for my taste. I purchsed a couple pieces of red oak wood and measured and built it from scratch. No longer veneer. I then put a coat of semi-clear polyurethane. You won't be able to use the original screws as they will be too short. The screw I purchased I think are M4 -.7. Can't remember the exact length. The screws in the pics are now gold in color. They blend in better with the wood.
DT-5 1 DT-5 2 DT-5 3
I believe the DT-510 is the same shell as the DT-5. If you need measurements let me know.
Have Fun,
Paul
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Sonic Craft
Organ Donor Parts
Vintage Home Audio
Parts Connexion
Wargos Electronics
Take Five Audio
Sonneteer
Audience AV
Sound Stage Direct
Simply Speakers
AudioClassics
Howard Products
AV Solutions
FM DX Antenna
Musical Paradise
Grant Fidelity
McIntosh Cabinets
Yesterday's Audio
BOI Audio Works
DeWick Repairs
Amplifiedparts
Politicalchat.org
RSL Speakers
Urban Antigue Radio
The Tube Store
Many Moons Audio
Audio Doctor
Videokarma.org
MCM Electronics
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
ęCopyright 2002-2014 AudioKarma.org, All rights reserved.
