macaltec
Metal Master
I got my record cleaner going this evening. It is functional but not finished cosmetically. I used some 1/2" copper tube as the suction arm that couples to a 1/2" rubber hose that couples to an adapter for my 1 gallon shop vac to plug into and well, it doesn't suck (gotta sort this one out some more). Leaves the record too wet. A small brush type attatchment on the vac hose does a much better job. The motor assy is just that, mounted to the bottom of a board and adapted from the shaft on one end and holding a turntable spindle on the other. Variable speed, cause that's what I had available. All mounted in a desecrated (not my doing) AR5 speaker cabinet. I guess I had unrealistic expectations of a static free experience with freshly cleaned records. I was sure that I was doing something wrong as I still have some snaps, crackles and pops (little bastards) in my records that had been cleaned. They are much more listenable now than before though. Maybe some pics tomorrow.
*Edit* My new avatar is of the first record I cleaned. Previously unlistenable.
I'll be passing by in a few weeks...
