Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
FORUM RULES
Reply
Thread Tools Display Modes
  #1
Old 07-28-2003, 09:15 AM
Wired Wired is offline
AK Member
phono stage resistance
Would it be better to run my TT into a phono stage with 50k ohms resistance or 100k ohms resistance?
__________________
Joel
<a href="http://www.audiokarma.org/gallery/showphoto.php?photo=721">View My System</a>
  #2
Old 07-28-2003, 09:42 AM
Lefty's Avatar
Lefty Lefty is offline
AK Member
Hi Joel;
It all depends on your cartridge specifications. Most MM (moving magnet) carts were designed for a 47K ohm load so the 50K ohm would most likely be what you would want to use.
Lefty
__________________
Lefty:
Cables? I don't got to show you no
stinkin' cables
038° 00' 58.68" -122° 15' 39.54"
134.84 ft
  #3
Old 07-28-2003, 10:43 PM
AK Member
What would change if I used the 100k ohms input?
__________________
Joel
  #4
Old 07-29-2003, 02:56 AM
michael w michael w is offline
AK Member
Better check your phono stage again.
AFAIK no phono stages have that high a loading.
Do you mean 100 ohms ?
Most go to 47k , which is unloaded.
What cartridge/phono stage combination are you using ???
Generally as you increase the load you tighten up the sound until you reach the extremes when it all sounds sterile and lifeless.
As you head the otherway towards 47k, there are improvements in transparency, dynamics, soundstaging until you reach a loose bloom.
Of course YMMV depending on your specific combination.
cheerio
  #5
Old 07-29-2003, 03:40 AM
AK Member
Here is the section in the manual of my reciever. I use a marantz 6110 turntable and have no idea which cart. it uses (might be the orginal). The receiver was is a sansui 4000 and was made in 1970.
Which input should I use?
__________________
Joel
Audiokarma
  #6
Old 07-29-2003, 06:25 AM
car67's Avatar
car67 car67 is offline
AK Member
Hi Joel,
Why not just try them both? Can't do any harm. But if you do, be safer to turn the amp off when switching inputs. I learned the hard way...
cheers
Jack
  #7
Old 07-29-2003, 08:15 AM
AK Member
Vintage phono stuff !
I better leave that to the experts.
Try 'em both and stick with the one that sounds best to you.
cheerio
  #8
Old 08-13-2003, 06:22 AM
EchoWars's Avatar
EchoWars EchoWars is offline
Lee Ho Fook's or Bust
Noise specs will always be better when you match impedence...that is where you get the maximum power transfer from cartridge to preamp.
However, you can certainly experiment. Won't hurt a thing.
  #9
Old 08-13-2003, 09:38 AM
grumpy's Avatar
grumpy grumpy is offline
Admin
As others have said most likely your running a moving magnet cartridge that is the standard 47K. Running it through the 50K would be the most logical. 100k is pretty standard for Moving coils but you can try it out for shits and giggles.
Grumpy
__________________
"It's also difficult to judge pizza by a picture"
Pete1729
Don't forget about the best audio show in the Midwest. The 2010 www.akfest.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
AudioClassics
Grant Fidelity
Turntable Depot
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
Audio Atlanta
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
McIntosh Cabinets
Zebra Cables
Radio X
Venus HI-FI
vancouver audio speaker clinic
MCM Electronics
Politicalchat.org
Videokarma.org
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©Copyright 2002-2009 AudioKarma.org, All rights reserved.
