Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
FORUM RULES
Reply
Thread Tools Display Modes
  #1
Old 10-03-2006, 12:53 AM
jfine's Avatar
jfine jfine is offline
AK Member
Matrix stamper numbers
This is probably a long shot, but does anyone know if like a matrix stamper number chart from say, Capitol records, is available? For example by looking at a given run off number of
SKAO-406 - 1 - x5
versus
SKAO-406 - 1 - x3
I would assume the x3 is an earlier press, hence possibly a better sounding press because of the sound loss from each successive matrix stamp?
Another reason is it would be nice to know if you have gotten a first press or a fifth press if you knew first pressing matrix numbers.
I know there's a ton of info on collector beatle presses to figure out first pressings, but who figured that out and where is that info kept?
  #2
Old 10-03-2006, 10:06 AM
chosenhandle's Avatar
chosenhandle chosenhandle is offline
CUSTOM TITLE HERE
If I were looking at that record, I would probably check the Goldmine reference guide to determine the catalog number for the first pressing. In this case, I would assume the SKAO-406 would be that number, although there are cases where that isnt true. The second number I would see as the laquer number, the third set I would read as mother/stamper number. In your case, the record is the first pressing, first stamper, "X" mother and 5th (or 3rd) stamper.
Each laquer is different and therefore, the first may not be the best. Case in point is the Magical Mystery Tour German HorZu, where the second is by far the best. The mother/stamper numbers usually are a lot better the lower they are.
Each record company has its own way of doing it and I think I learned from experience. I personally have never seen a complete "capitol" or "EMI" reference chart.
There is an RCA discography online, mainly for the classical records.
__________________
My Mom called me Paul. My dad called me late for supper every night
  #3
Old 10-03-2006, 11:01 AM
trinescope trinescope is offline
AK Member
From what I've been able to come up with from a few different sources, the last two digits (letter, number) on Capitol indicate the cutting lathe and the lacquer number. For example, F4 indicates the fourth lacquer from the "F" lathe (a Neumann). The most common lathe codes are E, F (Neumann), G, H (Scully), and Z (outside mastering). I don't know the other lathe codes.
  #4
Old 10-06-2006, 09:20 AM
Jay Pemberton Jay Pemberton is offline
AK Member
Look over on stevehoffman.tv. William Brown (handle 'W. B.') who has written books such as a Columbia Records singles discography, has many postings there explaining the Capitol matrix codes, which also indicate which studio did a particular cutting.
  #5
Old 10-06-2006, 11:52 AM
AK Member
That's where I got my info as well.
pressing plant initials
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
AudioClassics
Grant Fidelity
Turntable Depot
DIY Hi Fi Supply
Audio Doctor
Simply Speakers
Afforable$
DeWick Repairs
Audio Art Cable
Parts Connexion
Audio Atlanta
Audience-AV.com
Sound Stage Direct
Vintage Electronics Repair
FM DX Antenna
McIntosh Cabinets
Zebra Cables
Radio X
Venus HI-FI
vancouver audio speaker clinic
MCM Electronics
Politicalchat.org
Videokarma.org
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
©Copyright 2002-2009 AudioKarma.org, All rights reserved.
