Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #1
Old 10-14-2006, 04:01 PM
jayzjayz jayzjayz is offline
AK Member
BSR XL- 1200 Linear Turntable
A few years ago I purchased BSR XL-1200 Linear Tracking Turntable. It was working fine at that time. I packed it away along with some other old stereo equipment,also in good working condition. Now to my problem?
The turntable turns on and both speeds work but when you hit the play button the arm does not work and does not track at all.
Does anyone know what this problem could be. Can this problem be fixed by me or do I need to get it repaired professionally.
I would be grateful for any ideas or help.
Jayz
my email jayzjayz@verizon.net
  #2
Old 02-09-2009, 01:32 PM
Nat's Avatar
Nat Nat is online now
AK Member
Old thread, but was looking at this exact table found at the dump in its box with manual. This is a pretty low end linear arm table, so probably not worth spending money on, but it seems pretty simple to repair, or at least to check out.
First, look at the bottom (either hold it above you, or remove the platter and turn it over) and see if you put the transit screws in before you put it away -- that might be the problem. They are usually red painted, and the two that lock the arm mechanism are in the back left hand side. If they are there, take them out.
If that doesn't solve it, with the platter off and the stylus removed, unscrew the screw near the spindle with the electric bolt sticker pointing at it. Pop out the section of plastic that the screw holds down, and use the fast forward button to position the arm over that gap. Unplug the table so that the arm stays there.
Flip the table on it's dustcover (rest it on a piece of cloth), and remove the feet and the screws around the periphery of the metal plate and remove it. Now remove the screws at the back of the remaining plastic bottom plate, and lift it out carefully, making sure you don't whack the arm against the plinth. The arm mechanism is on the plastic bottom plate and you'll have to maneuver a little to get it to flip over so you can look at it.
There are two potential easy to fix problems - the grease on the slides may have dried up (not a problem on mine, so probably not on yours either) or the belt that drives the arm mechanism may be loose or broken. There is a motor on the plate that drives a chopper (a disc with slots in it for a photodiode and detector to sense motion) which in turn drives the arm motion. If that belt is loose or broken, it needs to be replaced. To do that you have to take the chopper/worm screw out of its pivots, but it appears to be held in them simply by the tension of the belt. And if its fallen out, that suggests the belt is broken or loose.
You can also see a cam on the arm carriage that obviously adjusts how much deflection the arm has before it moves, but I wouldn't touch that.
Hope this helps someone.
  #3
Old 02-09-2009, 01:41 PM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
Last of the Time Lords
A BSR linear tracker? Considering some of the BSR tables I've seen, this seems like a potentially bad idea...
  #4
Old 02-09-2009, 02:24 PM
Nat's Avatar
AK Member
Well, I wouldn't recommend anyone run out and get one, but if you have one or are curious how they work (or how it was possible to make them so cheaply), its an easy one to get apart. Sometimes the appeal of things is working on them, not using them -- and this is a lot cheaper than a boat.
  #5
Old 02-09-2009, 02:49 PM
wilkes85 wilkes85 is offline
Banned
a linear tracking BSR? hm... I want one lol, as a novelty if anything.
It would probabally be the only BSR turntable that ever tracked properly.
Audiokarma
  #6
Old 02-09-2009, 02:51 PM
Sansui Louie's Avatar
Sansui Louie Sansui Louie is offline
Curmudgeon
It would seem to me that if BSR had a linear tracker, it would have been in the mid to late 80's, and it was probably badged BSR and made by someone else. I wouldn't expect it to be a great performer but I am darn curious as to what it is. Pics?
  #7
Old 02-09-2009, 03:08 PM
Sam Cogley's Avatar
I'm not so sure about that...LTs have a reputation (possibly undeserved) for not living up to their concept. A BSR seems like a good way of really screwing up the tracking.
That said, my parents have owned a ceramic-cartridge BSR cheapie since the early 70s (if not earlier). It's always done its thing without issue. Certainly not an audiophile piece, but it doesn't eat records alive either.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Tone Arm Audio
Tuner Heaven
Classic Sound Repair
Take Five Audio
Acoustic Sciences Corporation
Audience AV
Cabledyne
BD Enterprise
BOI Audio Works
Howard Products
Amplifiedparts
Audio Art Cable
RSL Speakers
Siliconray
Salk Sound
Vinyl Magic Record Cleaner
Musical Paradise
Audio Salon
Urban Antigue Radio
Grant Fidelity
Many Moons Audio
Yesterday's Audio
McIntosh Cabinets
Simply Speakers
The Tube Store
DeWick Repairs
AudioClassics
Parts Connexion
Audio Doctor
Vintage Electronics Repair
MCM Electronics
Politicalchat.org
Herbies Audio Lab
Antique Radio Classifieds
Sound Stage Direct
Videokarma.org
FM DX Antenna
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
©Copyright 2002-2012 AudioKarma.org, All rights reserved.
