mhardy6647
Lunatic Member
OK, so the Big Boss at work, knowing of my hi-fi proclivities, offered me his Carver receiver (Mrs. Big Boss has requested that it depart the basement). He encouraged me to make sure Mrs. H wasn't aware of its source!
He thought there was something wrong with it, and by Jove he appears to be right about that! When plugged in and turned on, there's a pilot light on the main display which lights (sort of an edge lit effect), and the "infinity" (negative infinity) LED's on the signal level meters light, but none of the function switch LED's lights. If one presses an input selector (say, FM), the LED associated with it lights, dimly, while the switch is pressed, but goes out when one removes finger pressure from the switch. The tuner display doesn't. Needless to say, there's no output (not even hum or hiss)... I've only tried cheap headphones. I've not checked for DC on the outputs.
This is one of those nameless Carver receivers (I know, they're named "Carver Receiver"). It says "Magnetic Field Power Amplifier" on the front -- shades of the Carver "Cube" :-O
Can any of you Carver gurus ID this particular Carver Receiver?
I've never owned any Phase Linear, Carver (well, I do have a Carver CDP I found at the dump), or Sunfire equipment, so this would be interesting to hear and to play with. Is there any hope for this rascal? Any tips on where to start would be greatly appreciated and gratefully received!
Thanks for your attention!
