Omron and Panasonic Relays at Digikey
Despite the purchaser at Digikey saying that he'd email me when they were available, he did not. Regardless, Digikey now stocks quantities of PC-mount relays (they have already carried the solder lug style for quite a while) . Here's some numbers:
These are by far the most common ones used in 70's Japanese gear, especially the MY4-02-DC24.
Note that the LY-type relays are not often used as speaker protection relays (but I think Yamaha does use them in some gear, as does the Sansui G-8000/G-9000), but they are often used in soft-start circuits in larger amps (and these usually are chassis mounted, not PC-mounted). Also note that, for quick identification, Omron has been used as the OEM relay for years, and many relays will say right on top of them 'MY4' or 'LY2'. At any rate, the LY-style relays have the coil pins spaced farther apart than the contact pins, and they are rotated 90° from the contact pins. The MY-style relays have the coil pins and the contact pins all lined up in a row.
FYI...don't screw around with pulling apart PC-mount relays to clean the contacts if you can get a new one. If these do not sell at a reasonable pace at Digikey, they will stop carrying them, so order-up.:yes:
Edit: Digikey now also carries Matsushita (Panasonic) relays, perfectly suitable to substitute for a few of the above Omron relays, as well as a couple that Digikey does not carry in the Omron brand. These are all 'MY'-style relays (except the HL2 DTDP 12V relay), with both the contact pins and the coil pins lined up in a row.
Edit: Potter & Brumfield relays carried by Digikey
Mouser carries the 3PDT relay that the Sansui 9090db requires:
'Nother Edit: Digikey also carries a perfect replacement reed relay for the Kenwood 700C (Edit within the edit: A few 700c's use a shorting relay, and this will not work with those units). This is the US Relays DPDT 24V open-line relay, Digikey part number Z649-ND. The NC pins have to be cut off the new relay to fit the board, but other than that it is perfect. (You may note that the original relay in the 700C has a ground connection. This is simply a shield for the relay, and is not strictly needed. Note that if you do not clip the NC lead off that side of the relay, the contact will be shunted to ground. Do not allow this to happen...cut the NC leads off!)
Code:
[b][u]Omron PN Digikey PN Description[/u][/b]
MY2-02-DC24 Z2633-ND DPDT, 24VDC, PC-Mount
MY4-02-DC24 Z2634-ND 4PDT, 24VDC, PC-Mount
LY2-0-DC24 Z977-ND DPDT, 24VDC, PC-Mount
LY2-0-DC12 Z978-ND DPDT, 12VDC, PC-Mount
Code:
[b][u]Panasonic PN Digikey PN Description[/u][/b]
HC2-HP-DC24V-F 255-2762-ND DPDT, 24VDC, PC-Mount
HL2-HP-DC12V-F 255-2395-ND DPDT, 12VDC, PC-Mount ('LY' style)
HC2-HP-DC12V 255-2761-ND DPDT, 12VDC, PC-Mount ('MY' style)
HC4-HP-DC12V 255-1920-ND 4PDT, 12VDC, PC-Mount
HC3-HP-DC24V 255-2209-ND 3PDT, 24VDC, PC-Mount (dropped)
HC4-HP-DC24V 255-1921-ND 4PDT, 24VDC, PC-Mount
HC4E-HP-DC48V 255-1924-ND 4PDT, 48VDC, PC-Mount (dropped)
Code:
[b][u]Potter & Brumfield PN Digikey PN Description[/u][/b]
K10P-11D55-12 PB327-ND DPDT, 12VDC, PC-Mount (LY-Style)
K10P-11D55-24 PB328-ND DPDT, 24VDC, PC-Mount (LY-Style)
K10P-11D55-110 PB451-ND DPDT, 110VDC, PC-Mount (LY-Style)
Code:
[b][u]Panasonic PN Mouser PN Description[/u][/b]
HC3-HP-DC24V-F 769-HC3-HP-DC24V-F 3PDT, 24V, PC-Mount (MY-Style)
