They are 14.5V 80mA bulbs. I have replaced one of mine with a white LED with a series resistor and a diode (20mA result), plus another 2W resistor in parallel to get the 80mA.Martin.Ca said:I *think* those stupid bulbs are just 12v 60ma ones in series.... but at the rate they "don't" last, maybe they're supposed to be 14volt.
It's a nice amp. You can check my webpage about it here:nkrisher@hot said:Thanks - I'm going to bring the amp in and give it a good cleaning/tune up. Hopefully they can replace the bulbs. I'm planning on setting up a turntable again for the first time in about 100 years & using this amp as the centerpiece for my "retro system"
Gigapod said:They are 14.5V 80mA bulbs. I have replaced one of mine with a white LED with a series resistor and a diode (20mA result), plus another 2W resistor in parallel to get the 80mA.
Gigapod said:It's a nice amp. You can check my webpage about it here:
http://gigapod.free.fr/Yamaha_A760.html
Some parts are unobtanium, so it's a fragile piece.
(edit)
Here is the relevant part of the schematics:
