Very simple.
*Take a single speaker, and put a cable on its terminals. Place this speaker behind your main listening chair. It's best to have one that matches your other main speakers so they'll all sound the same.
*Take that cable, and put one end on the Left B-channel's "+" terminal, and the other on the Right B-channel's "+" terminal. Leave the "-" terminals empty.
(This will not work on an amplifier that has A+B connections in series. To test, have only one pair of speakers set up on your amp, on the "A" terminals. If you can still hear sound from your main speakers when you put the speaker selector switch on "A+B", then this will work for you.)
*Turn the amp down to 0, put the amp in Mono, turn on the "B" terminals, and power up the amp.
*Now to adjust for proper balance. Turn on your FM tuner to a mono signal. Turn up your amp's volume to a fairly low level. Adjust your Balance control so that you get minimum output from that one speaker.
*Switch your tuner to Stereo. What you're now hearing is the electrical difference between the Left and Right channels. Most often, you'll hear echoes, ambient sound, backing vocals, other instruments. This will work with all input sources: CD, LP, tape, FM...
*Put on a CD or LP, and switch your amp to "A+B". The rear channel on "B" will give you a derived "surround" or third channel. Some people use an L-pad to adjust the volume for more realistic ambience.
Tom
