240 Volts
Strange, yet oddly normal
I recently acquired a Trio KR-9600 receiver in very good condition (bought it on a well known auction site). Upon checking it out I found that the output DC offset was approx 120mV on one channel and 130mV on the other. The KR-9600 does not have adjustment pots for offset, so the only way of reducing it is to replace the differential amplifier transistors.
I discussed this with the seller and he has managed to find a UK source for the original 2SC1345 transistors, but there are only 6 available at a cost of £2 each (approx $4 each). Now the chances of getting two reasonably matched pairs from only 6 transistors is extremely remote, so I am very reluctant to ask him to get them for me (he agreed to pay for the cost of parts to bring the receiver up to spec if I would fit them).
I can get Zetex ZTX694B alternatives (mentioned by EchoWars in other threads) for £0.71 each ($1.40), but would have to buy quite a few (25??) to be able to get the two matched pairs I require. While looking for alternatives I came across the On-Semi BC550C, which is a low noise transistor with very similar specs to the original 2SC1345 (the Vc-e voltage rating is 45V instead of 50V but I don't think this will be a problem in the 9600). The cost of the BC550C is only £0.04 each for a quantity of 25, or £0.02 each for 100, so I could buy lots of them in order to get closely matched pairs.
The data sheets for the 2SC1345, BC550C and ZTX694B are attached below. Opinions please regarding the use of the BC550C as a replacement for the 2SC1345. :scratch2:
Thanks,
Richard B.
Thanks,
Richard B.
