Hello,
making transistors for high-power amps was hi-tec in the 70ies. The pnp type transistor, for complementary pairs was even more complicated - that's why early transistor amps had only npn transistors in the output stage (quasi-complementary design, mostly ac-coupled, output capacitor, one supply voltage)
The Marantz 2270 had complementary npn and pnp output devices, Motorola SJ2517/18 in the beginning. During its long production span, it got all the transistors that came in style over the years. Maybe Fairchild was cheaper and/or better than the old Motorolas.
Early 2270 had everthing made in Japan, transistors by Toshiba/Hitachi, circuit boards by ELNA, capacitors by ELNA except output transistors: Motorola, Texas Instruments, Fairchild. Looks to me Japan did not have the know How in the beginning?
As from a today's standpoint, don't bother to search for the number stamped on your 70ies transistor it is 99% obsolete. If you do get that device, it's probably a fake, or a modern chip with the old number stamped on it, or it is overpriced NOS....just my 2 €-cents
Helmut
