analog addict
Glory or Death!
Is this thing usable at all in audio applications? Does anyone have any experience with them? Here's some additional info from the web...
MPA-250 250-Watt Stereo Public Address Amplifier
(320-2004) Features Faxback Doc. # 51679
Your Optimus MPA-250 250-Watt Stereo Public Address Amplifier gives you
the versatility and power you need in a professional sound system. Its
wide frequency response easily handles amplification of voice and music.
Use it in meeting halls and auditoriums, at sports events, in schools, and
in the office for paging systems - anywhere you need to deliver special
announcements with excellent sound.
The amplifier (if bridged) produces up to 350 watts of clean, powerful
sound with minimum distortion.
Your amplifier includes these features:
10-50,000 Hz Frequency Response
Built-In Cooling Fan - helps protect the amplifier by reducing its
internal temperature.
Two Mounting Options - you can mount the amplifier in a standard
sized audio equipment rack or on a desk,
shelf, or table.
2 lighted VU Meters - measure the amplifier's output for each
channel in decibels.
Left and Right Output - lets you adjust the overall sound level on the
Level Gain Controls left and right channels.
Clipping Indicator - lights if a sound source signal overdrives the
amplifier.
Phones Jack - lets you connect headphones so you can listen
privately.
Bridging Capability - you can combine the amplifier's two channels
and use the amplifier with only one channel,
producing a total of 350 watts.
Meter Range Select Switch - lets you control the meter's sensitivity.
Input Jacks - lets you connect a variety of audio input
sources for music and special effects.
A/B SPEAKER Switches - lets you select the speakers you want to use
with the amplifier.
STEREO/MONO Switch - lets you select the output type; stereo or
mono (bridged).
Binding Post Terminals - lets you easily connect wires directly to the
amplifier.
Switched AC Outlet - lets you power other devices by plugging them
into the back of the amplifier.
Thanks....
shelf, or table.
amplifier.
privately.
with the amplifier.
mono (bridged).
amplifier.
Thanks....
