Audiokarma.org
Audiokarma Featured Sponsor
Go Back   AudioKarma.org Home Audio Stereo Discussion Forums > Turntables
We appreciate your help
in keeping this site going.
Reply
Thread Tools Display Modes
  #466
Old 08-11-2009, 01:32 PM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
Last of the Time Lords
Titebond II is what I normally use.
Aileene's is available in the craft section at Wal-Mart.
__________________
Growing up leads to growing old and then to dying,
And dying to me dont sound like all that much fun...
-John Mellencamp
Burn the land and boil the sea...you can't take the sky from me.
-Joss Whedon
  #467
Old 08-11-2009, 01:41 PM
relder relder is offline
AK Member
Quote:
Originally Posted by Sam Cogley View Post
I've done it to a copy of DSOTM. I have a couple of plastic spreaders used for spreading wood putty and similar substances that I use for glue spreading. Hopefully I won't need them much longer, my RCM is almost done.
Keep 'em around, even though I have a VPI RCM I still resort to glue for LPs that are still noisy after RCM. It can incrementally help over a RCM cleaning, depending on cause of noise.
Rob
  #468
Old 08-11-2009, 03:58 PM
John C.'s Avatar
John C. John C. is offline
AK Member
Quote:
Rob
Right.
Sometimes you need both.
  #469
Old 08-11-2009, 04:15 PM
Mopic5's Avatar
Mopic5 Mopic5 is offline
AK Member
Yeah, I've slipped over to using Titebond II as my "go to" choice. It does peel off easier than original formula Titebond - so this for me is an ease of use issue. A few pages back an AKer discovered that Titebond "Extend" actually self-peels as it dries - a real boon to the process. Haven't been able to find it locally in the North, but it's readily available in Southern states where longer set-up time for actual wood glueing projects is desired. I've been a slacker in not ordering a pint to try with an A/B (side 1 / side 2) test to confirm that it cleans just as well as Titebond I/II.
- Mario
  #470
Old 08-11-2009, 04:36 PM
JonL's Avatar
JonL JonL is offline
Tubeulosis vinylitis
I hardly ever make it to Wal-Mart. The closest one to me is fortunately a bit of a drive.
__________________
Main: AI Modulus IID, Dynamutt Octal Stereo 70, B&O TX2/SoundSmith SMMC-2, Thorens TD125/Shure M75HE, Denon DRM800A, Teac A3300S, Sony DVPNS77H, Klipsch LaScala
Office: iPod, Dyna SCA35, Celestion DL8-II or AR-2
Audiokarma
  #471
Old 08-11-2009, 04:53 PM
JohnMac's Avatar
JohnMac JohnMac is offline
AK Member
Wonder it would work on my old copy of "Sticky Fingers"? Or "Stuck On You"?
  #472
Old 08-11-2009, 05:34 PM
enricosonic's Avatar
enricosonic enricosonic is offline
Just don't use it on a Woody Guthrie record.
  #473
Old 08-11-2009, 07:55 PM
Sam Cogley's Avatar
Quote:
Got a Michael's or a Hobby Lobby handy? Both should have it.
__________________
-John Mellencamp
-Joss Whedon
  #474
Old 08-11-2009, 08:22 PM
JonL's Avatar
Yup. I'll be passing a Michael's tomorrow afternoon. I'll stop in.
__________________
  #475
Old 08-11-2009, 10:06 PM
hrgiger hrgiger is offline
AK Member
Quote:
Originally Posted by hrgiger View Post
And here it is again after some digital wizardry, not perfect, but pretty close, compared to the first one!
OOoops, here is the link somehow I didn't get it posted.
After only audioquest brush and pad and D4+ fluid:
http://soundclick.com/share?songid=7924622
After Aleene's Tacky Glue:
http://soundclick.com/share?songid=7924639
The missing link: Only this last link had any sort of click and pop removal by computer.
http://soundclick.com/share?songid=7944688
Audiokarma
  #476
Old 08-12-2009, 01:43 PM
dobyblue's Avatar
dobyblue dobyblue is offline
Blu-ray Guru
So a "crafts" store is going to be a better place to look than a hardware store right?
The hardware store sells "LePage Plastic Wood" and "LePage Carpenter's Glue" and I don't think I want to be the guinea pig here.
EDIT - looks like if I can't find any at a crafts store or Home Depot that I can just order it through Amazon.com
http://www.amazon.com/s/ref=nb_ss_hi...ds=titebond+II
  #477
Old 08-13-2009, 02:37 AM
SaSi's Avatar
SaSi SaSi is offline
Rediscovering analog
If you can see "PVA" or "Poly vinyl acetate" in the sticker with the composition or description, then you will be fine.
I have found that the "fast setting" carpenter's glue is somewhat better in taking off (creates a thicker film at the edges) seems finer when applying in the grooves, sets faster (as advertised) and seems to remove a bit more grit. This last part is highly subjective and difficult to prove as avery LP is a different one in terms of grit quality, quantity and ageing.
  #478
Old 08-13-2009, 03:07 PM
AK Member
Yes, you can get Aleene's at a craft store or at any type of fabric store, and most likely at any big store that has departments like those (walmart, kmart, meijer's, hobby lobby, michael's, etc.)
At Joann Fabrics, a gallon for $21 plus shipping (you can get the same deal on Amazon): http://www.joann.com/joann/catalog.j...PRODID=prd1784
Why you shouldn't sniff Aleene's tacky glue: http://www.associatedcontent.com/vid...acky_glue.html
  #479
Old 08-15-2009, 10:08 AM
spideyjack's Avatar
spideyjack spideyjack is offline
fun lovin' record pundit
Location: With my true love and a feral cat named Possum Girl.
ok I will play. I just glued up two "hard case" 45s. I had subjected both to my regular cleaning process, and wanted to see if this would take them a step further.
Sometimes it is hard for me to tell if the noise is from scuffs and scratches or groove gunk.
Both these 45s are from a big lot of soul and gospel that I bought in july, most of these have cleaned up reall well, but these two need an extra push. The Kansas City Melodyaires has so much surface noise that even by my standards it is hard to listen to. The Chuck Jackson starts out sounding great but gets worser and worser, making me think it has some deep funk gunk.
I will peel and play on sunday and let you all know what happens.
__________________
spideyjack
  #480
Old 08-15-2009, 12:27 PM
pmsummer's Avatar
pmsummer pmsummer is offline
simul justus et peccator
OK, I'm in.
Titebond II on a favorite Bill Evan's Fantasy release that looks great, but sounds like Rice Krispies. I live on the edge.
Follow up tomorrow.
__________________
P.M. Summer
Audiokarma
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Friends of Audiokarma
We appreciate your help in keeping this site going.
Tone Arm Audio
Tuner Heaven
Classic Sound Repair
Take Five Audio
Acoustic Sciences Corporation
Audience AV
Cabledyne
BD Enterprise
BOI Audio Works
Howard Products
Amplifiedparts
Audio Art Cable
RSL Speakers
Siliconray
Salk Sound
Vinyl Magic Record Cleaner
Musical Paradise
Audio Salon
Urban Antigue Radio
Grant Fidelity
Many Moons Audio
Yesterday's Audio
McIntosh Cabinets
Simply Speakers
The Tube Store
DeWick Repairs
AudioClassics
Parts Connexion
Audio Doctor
Vintage Electronics Repair
MCM Electronics
Politicalchat.org
Herbies Audio Lab
Antique Radio Classifieds
Sound Stage Direct
Videokarma.org
FM DX Antenna
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
©Copyright 2002-2012 AudioKarma.org, All rights reserved.
